C6 Telescopic Wheel
Old Oct 17, 2011 | 12:24 PM
vanman1980's Avatar
vanman1980
Default C6 Telescopic Wheel
Hey everyone ... an electrical question.
My telescopic wheel stopped working last week. It doesn't seem to adjust anymore ... and surprisingly, neither does my seat.
Could this be a fuse? Or maybe I just have to reset the memory on the key fob?
Any ideas or comments are welcome!
Old Oct 17, 2011 | 12:39 PM
Vette_DD's Avatar
Vette_DD
Check the connections under the seat.
Wouldn't hurt to check the fuses, but that not as likely the problem.
Old Oct 17, 2011 | 05:13 PM
FireRoc's Avatar
FireRoc
Agree. I had the power wire to the memory seat module break off. This module is attached to the bottom of the drivers seat. If the seat doesn't move it can be a real bear to get at.
Old Oct 17, 2011 | 05:26 PM
vanman1980's Avatar
vanman1980
I'll try that ... thanks guys! Your help and input is always appreciated!
Old Mar 4, 2013 | 11:52 PM
Boltfan555's Avatar
Boltfan555
St. Jude Donor '12
Having the same issue. What ended up being the cause?
Old Mar 5, 2013 | 10:40 AM
irok's Avatar
irok
your power seat module is causing the problem. it controls both the seat and telescopic steering.check under seat for a problem with harness at module.more than likely needs replacing p/n 15296303 around $125.just noticed this thread is 1 1/2 years old
Old Mar 5, 2013 | 01:08 PM
vanman1980's Avatar
vanman1980
It is my old thread ... I took it in to the dealership and and like irok said above, it's the seat module.
I couldn't get to it, so I took it in and got it fixed.
To C6 Telescopic Wheel
