I have a 08/LS3:When i had a Com cam installed it was a 1 bolt set up.I know nothing about the cams now days.All i know that when i picked up my car & i took the old parts with me:I just learned from this forum that the LS2 had a 1 bolt gear & the LS3 a 3 bolt gear.In the parts that i came back with there was a gear & 2 large bolts + the springs,push-rods & etc.Question is:Why did they put a 1 bolt set up in my LS3 ? Is that the way it is and can i expect it to hold up? Thanks
The 2008 LS3 cam is a single bolt cam gear. I just did a cam swap in my '08 last weekend. The 2 large bolts you have are most likely the old cam and crank bolts. They look almost identical. The crank bolt is a single-use bolt (stretch to fit) so once it's torqued down, that's it. You don't normally reuse it.
The 3 bolt cam gear came on the LS1/6/7 and has 3 smaller bolts instead of 1 big one. When I ordered my cam/cam kit, I specifically asked for a 3 bolt cam core, ARP cam bolts, and an OEM GM 3 bolt cam gear.
i think you have it backwards. ls2 is 3 bolt and ls3 is 1 bolt
Well how come i received a gear & 2 bolts back? There"s a tread on this forum that i read the other day about cams & I"m sure it said the LS2 used 1 bolt.The tread is about the guy wanting to put a LS9 cam in a LS2.If you can find that tread please let me know..Thanks
It would be strange if the B gear was returned because that's the gear you need if you're an LS3. I believe the A gear is for the LS2 as the cam position sensor is different in the 2 cars.
OK Justinjor:I have the gear in front of me now.It measures a little over 5 1/4" across & it is a one bolt gear part #1259`689.What gear is it ?
So the gear that is NOT in your car is the A gear? That is correct. Your shop should have installed "B" in your car now and given you the "A" leftover. You should also have 2 leftover bolts, big ones, that resemble each other.
Justinjor:I will try to figue out later on how to upload ,but like i said,the "A" gear is the one i have here,it has that slot right above the hole where the bolt goes in.What gear is that & why was it changed?
Reason: change a word
The slot right above the bolt hole is the indexing mark. There is a pin that protrudes from the front of your camshaft and ensures the timing marks are correct relative to the lobes and crank.
The front of the cam can have a single bolt pattern, or a 3 bolt pattern, depending on the year. It looks like GM used to put the 3 bolt in, switched to the single bolt for the LS2, then they changed right after the LS3 was introduced.
Well, that 1 bolt gear came off of my 08..Now I'm wondering what the shop put back on it ?? The kit was from Com cams.New push-rods,valve springs & i guess a new gear?No need to up load a pic,it is the "A" gear on Lingenfelter web.Sorry for bugging you so much,but lot of great guys on this forum.,
My car is an 08 as well and it had the single bolt cam gear. If your car is running and you have the single bolt cam gear as a leftover, then they put on a 3 bolt gear, which is correct.
I would assume the shop ordered the correct 3 bolt cam gear when they ordered the cam and the supporting mods.
Got it dyno'ed yet?
Now" That makes sense,it was upgraded.I'm sure they put the correct gear on,like i said the kit is from a well known vendor here in Texas.It was dyno'ed when they put the cam in,and later i had AR long tubes,K&N & borla stringers then they put it back on the dyno & I told the tuner not to go 100%,cause i don't race it,just want it to sound good.It is at 448 to the wheels now.Thanks again Justinjor,,Time for a Budlite
Forgot: Like i said i do have 2 large bolts left over(same size)Last question:Where did the 2 bolts come from?
