Transmission Fluid
Old Oct 23, 2011 | 10:23 AM
LKicklight's Avatar
LKicklight
Default Transmission Fluid
Getting ready to change my trans. fluid in our 2007 MN6 LS2 Coupe..Understand the RED LINE Fluid is far superior to the stock DEX III specified by GM...Need to know from someone that has done this to know how much fluid is required....thanks
Old Oct 23, 2011 | 10:29 AM
C7&7's Avatar
C7&7
Kind of depends on your car. In my 2005 it took about 1.8 quarts. I have read from 1.6 to 1.8.
However I just filled mine until I could put my pinky in the hole (lol) and feel the fluid. This is the way I would do it just to make sure it's full.
Oh, and I went with the GM DEX III and the tranny fills great. Also did the differential at the same time.
Old Oct 23, 2011 | 01:42 PM
Nightstalker Medic's Avatar
Nightstalker Medic
http://forums.corvetteforum.com/show...n+fluid+change
http://forums.corvetteforum.com/show....php?t=1497063
I thought it was 4 Quarts for the Manual Transmission. I used Royal Purple Synchromax.
Two Quarts for the Rear Gear Fluid (I used Amsoil Severe Gear Synthetic Extreme Pressure (EP) 75-90) with 4 oz. of Amsoil Slip -Lock Differential Additive. Do about 10 figure eights in a parking lot somewhere after the lube change. Its important to get the new gear lube up into/clinging to the packs.
Old Oct 23, 2011 | 01:55 PM
C7&7's Avatar
C7&7
Oh you're right. I had the diff on my mind. The tranny is 3.6 - 4
Old Oct 23, 2011 | 01:56 PM
timd38's Avatar
timd38
RedLine works great. I put it in and it shifted smoother.
Old Oct 23, 2011 | 08:49 PM
LKicklight's Avatar
LKicklight
Default Amount
So, the tranny takes 3.8 to 4 qts..correct...not the diff. just the tranny..
Old Oct 23, 2011 | 08:55 PM
GOLD72's Avatar
GOLD72
That is correct. I have changed tranny fluids on several vettes. It will definitely not take 4 qts to refill. Actually it will be just less than 3.8 qts.
Old Oct 23, 2011 | 09:03 PM
Hoonose's Avatar
Hoonose
I was disappointed and found it changed nothing.
Old Oct 23, 2011 | 09:42 PM
bingo1105's Avatar
bingo1105
I changed mine to Redline about six months ago. It's still occasionally difficult to put the car in first gear at a stop, but the improvement has been noticeable for me. Maybe the improvement was just due to fresh fluid... not sure...
Old Oct 24, 2011 | 07:19 AM
GOLD72's Avatar
GOLD72
I used Redline D4-ATF in my 01Z and didn't really see an improvement. Also used AMSOIL ATF in the 06Z also with no real improvement. Both changes were done at ~20k. Both were still worthwhile changes at the time and upgraded the factory fill mineral oil DEX 3 to full synthetics.
To Transmission Fluid
