Oil/Coolant migration issue.
Old Oct 23, 2011 | 11:44 PM
Corvee's Avatar
Corvee
Default Oil/Coolant migration issue.
My C6 Z06 is loosing coolant without external signs and no engine smoke. The oil is now contaminated with what appears to be coolant (foamy chocolate milk). Could this be attributable to a head gasket failure or something internal? The block is a Darton resleeved LS7.
Old Oct 24, 2011 | 08:47 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Any white or swirls in the oil is almost always coolant. There's an coolant test kit available from napa that will test for exhaust in the coolant. If you have either coolant in the oil or oil in the coolant, you've lost a head gasket or worse.
Old Oct 25, 2011 | 07:28 AM
taken19's Avatar
taken19
Track Junky
+1 on the head gasket.
Old Oct 25, 2011 | 12:19 PM
carlrx7's Avatar
carlrx7
St. Jude Donor '08-'09
Do you have an eoc in your radiator? If not then I'd say head gasket as well. Sorry
Old Oct 25, 2011 | 04:54 PM
KB9GKC's Avatar
KB9GKC
Hello,
Sounds like head gasket.
Douglas in Green Bay
Old Oct 25, 2011 | 05:37 PM
VET4LES's Avatar
VET4LES
Old Oct 25, 2011 | 06:09 PM
Anthony @ LGMotorsports's Avatar
0Anthony @ LGMotorsports
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
Could be from a couple different area's.
Do you have a radiator with a engine oil cooler built in? Check to see if there is a leak there....the engine makes more oil pressure than water pressure so the oil level would drop and would go into the water.
If the head gasket is blown, there is more cylinder pressure than water pressure, and the cylinder pressure would then force the water out....when the engine is shut off, it generally leaks into the cylinders and hydro locks, or burns out through smoke.
There can be a leak at the head gasket, that would cause oil draining back from the top of the engine into the water system. This would cause a milky oil condition as well.
Generally you will see oil level rise as well as coolant dropping.
Old Oct 26, 2011 | 12:04 AM
Corvee's Avatar
Corvee
Anthony:
The radiator is a Ron Davis with an engine oil cooler. The radiator is pulled and being pressure tested. The car had no smoke, and the oil level was higher (hot) with the milky brown froth but but returned to normal level when it cooled down.
Jim
Old Oct 28, 2011 | 02:16 PM
Former Vendor
Originally Posted by Corvee
Anthony:
Jim
Jim,
Any word if the radiator was busted?
Old Oct 28, 2011 | 03:18 PM
Bobby @ LG Motorsports's Avatar
0Bobby @ LG Motorsports
Former Vendor
If its sleeved, the sleeve dropped, or the gasket is compromised.
Old Oct 28, 2011 | 04:39 PM
Bill Suttie's Avatar
Bill Suttie
If coolant gets into your engine oil it will destroy the lubricity of the oil. Get the coolant to oil leak fixed ASAP before the engine is toast.
Old Oct 31, 2011 | 10:59 PM
Corvee's Avatar
Corvee
Jim,
Anthony:
A delay with the radiator shop and I have been out of town since the end of last week. I will hopefully know something tomorrow.
Bobby:
The plugs were clean - without any evidence of unusual discoloration or oil. Most of the contamination appeared to be in the oil and not the coolant, although the coolant was slightly milky and had been recently changed. The front catch can was full of coolant/oil mix (mostly coolant) and the back catch can (you will remember I have the ARE system with the breather) was full of oil (little or no coolant present).
Bill:
She is parked until the problem is sorted out.
Old Nov 1, 2011 | 12:21 AM
Louis @ LG Motorsports's Avatar
0Louis @ LG Motorsports
Former Vendor
Good luck with it! Let us know if we can be of any help
Old Nov 1, 2011 | 06:43 PM
Corvee's Avatar
Corvee
Thanks Louis. Anthony and Bobby helped me out of tight spot last spring.
The radiator checked out fine, so it is not the engine oil cooler. My local mechanic is going to check the head bolts and then pull the heads tomorrow if necessary.
Jim
To Oil/Coolant migration issue.
