How much power is too much??
I really appreciate the input. It seems like a clutch and possibly the diff should be upgraded to be safe.
And Greentahoe you make a good point. This C6 may be the fastest car I have driven. I haven't driven a Z06 or turbo or sc'd vette. You make an interesting statement that you have and the next build you do will be na. I have thought about a na build but the sc seems to be less fuss and easier on the engine. A na build will require high lift cam, better rockers, larger push rods, higher pressure springs, etc. All of this is in use so to speak on every rotation. The sc route only 'kicks in' when you want it.
As has been stated, I don't 'need' more hp. I could probably say something similar about everything I own. But i had a blast working on my first car, a 1969 Z28 over 40 years ago. I had a lot of fun putting in a cam, headers, big carb, etc. Boy do I wish I had that car now... But after raising a family and now enjoying 6 grand kids, I have the time and funds to have a little automotive fun again. And I really appreciate a forum like this to learn from others failures and successes. I'm going to make better and more informed choices because of it!
When you say "track the car" do you mean drag race or road race? If you are talking road racing, until you get better, I would say anything more than stock is too much. I've drag raced higher rwhp cars than my new Corvette, but I'm going to start doing HPDE at road courses. When my skill level at the track gets to the point where I can actually use more power I will mod the motor. Until then, it's just suspension and brakes for me.
500-550rwhp is enough for me.
I'm at 420 with bolt ons(ls3) and want to add a 100 shot later on. I want the nitrous to hit in 2nd gear around 3k rpms. So if I'm at a light I can drop the clutch from like 4k in 1st hook and book and bang second and bam 500+ hp. Lethal if you can hook from stops and low rolls....
besides there are days when I just like to take turns and really get on the gas. I don't want to worry about my *** end flyin out.
but I can see the attraction to lot of hp. It's what every puts a smile on your face.
Here's something I would throw out there:
I would say that for a street driven car, the Corvette pretty much stops being "fun" after roughly 800 RWHP and starts feeling more and more like "work" to drive above that. In other words, the constant struggle for traction every time you step on the throttle just takes the fun out of driving.
What do you guys think?
I disagree, suspension and tires make a huge difference. If the car is set up correctly the power is very manageable. Is say over 1050 things start to get sketchy regardless of setup. Even then though, especially with a centri or turbo, its power on demand. It only goes as fast as you want it to.
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
Driving the cars can be pretty easy.....again it is going to depend on how the car makes the power, setup can be everything.
The big thing that a lot of guys don't think about is wear and maintenance costs. At say 1000 rwhp you have more than doubled the power output of the car. If you think it is going to last 100,000 miles with only fuel and oil changes you have another thing coming. Look at the Bugatti repair lists...and that car was designed from the ground up to make that power, in a word...it is still 'Stock'
Received 4,565 Likes
2016 C2 of Year
2015 C3 of Year Finalist
IMO the amount of horsepower that is right for you is dependant on two things: 1. Driver skill and 2. The ability of the car to put the horsepower to the ground. I love fast cars, always have. Big blocks, small blocks, whatever. I find that my Z06, even in stock trim, has difficulty putting the power to the ground in first and second gear, especially in cooler weather.
My honest opinion on this. If the car consistently hooks up and pulls through the gears, it gets boring quick. A car that just blasts the tires and still has great acelleration is much more fun. my 2 cents
#33
Tolero Apto Victum
http://www.centurytransmission.com/home
http://rpmtransmissions.com/
#35
Hp
#36
Nah. You're just a wuss then.
The OP still hasn't said what kind of track events he's talking about. You can't beat a turbo setup for daily driving. You can run low boost or high boost. Even change it on the fly. Boost by gear and a myriad of other options with the fancy electronic boost controllers. Some even put CO2 on the wastegate to keep it shut without cracking open prematurely. If you are road course racing a turbo setup really needs to be well sorted. The Miata guys that road race turbos have gone through a lot of trial and error on what works and what doesn't. Pretty much it has to be top of the line parts and materials to survive on a road course. A drag strip and daily driving, not so much.
#37
That edelbrock kit is just too much money for the power, you can get an A&A Corvette Vortech Installed/Tuned for less than just the kit alone of a edelbrock and make just as much if not more power. Plus thats not the type of S/C I'd want on such a light car imo
#38
You guys think forced induction is expensive for Corvettes, try a GTO. I couldn't believe how inexpensive the A&A kit is. Some places are doing them for $6300-$6800 installed and tuned. You also make a valid point about a roots blower on our light cars. Very hard to get traction with that torque tabletop they make.
#40
I used to say never too much power , my ZR1 is 750. Right now, this time of year, I have trouble accelerating quickly as the temps are cool and the roads cold, this thing spins at will even in 3rd at half throttle, so if I am in a hurry I have to feather it, then try and get on it, it spins, get off it, back on it easier and so on and so forth. DO I wish I had only 638 hp? NO.
So I was thinking you could never have too much power. But after seeing your Avatar, I'm thinking of something else you can't have too much of!
