Spark plug gap
Old Nov 6, 2011 | 03:28 PM
Tally Ho's Avatar
Tally Ho
From: Out Where the Buses Don't Run, Eglin AFB/ Niceville FL
2022 Corvette of the Year Finalist -- Modified
2021 C6 of the Year Winner - Modified
2020 C6 of the Year Finalist - Modified
Default Spark plug gap
I'm getting ready to install the AC 41-104 plugs in my 2006 supercharged LS2 to hopefully get rid of the random "Service Charging System" message. What is the recommended plug gap for these in this application? I currently have NGK's installed. Thanks.
Old Nov 6, 2011 | 04:35 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Elmer
Old Nov 6, 2011 | 04:58 PM
TNTC4VETTE's Avatar
TNTC4VETTE
Will work for HPDE time.
I'd run a little less gap on an FI car. Depending on how much boost, between .032 and .038, so you don't end up blowing out the spark. Is this a TR6 equivalent? (One heat range colder)
Old Nov 6, 2011 | 05:06 PM
eboggs_jkvl
Moderator emeritus
Why less gap? That gap is what the ZR1 uses on the very same plug.
Elmer
Old Nov 6, 2011 | 05:30 PM
TNTC4VETTE's Avatar
TNTC4VETTE
Well, there's a few reasons. He isn't driving a ZR1. He has a LS2 car with an aftermarket centrifugal blower, which may or may not be running double-digit boost #s. Factory NA gap is .040. I experienced spark blowout at .035 and 12#s of boost in my turbo LS2 with TR6s.
Elmer, I see you have a FI car as well. If it's working for you, it might work for him as well.
Every car's different.
Old Nov 6, 2011 | 06:10 PM
Tally Ho's Avatar
Tally Ho
Thanks guys. I'm running on the conservative side at 7-8psi boost max. The NGK's were set to .040 so I was pretty sure these would be the same but I wanted to verify with some of you that have been running FI longer.
To Spark plug gap
