C6 differential Opinión
Old Nov 16, 2011 | 02:22 PM
os4car's Avatar
os4car
Default C6 differential Opinión
Guys I removing my rear end to swap for another one.
While I am doing this is there anything else I should try to change down there.
I appreciate all your help.
Old Nov 16, 2011 | 02:31 PM
LS1LT1's Avatar
LS1LT1
Need more info...
Manual or automatic?
Rear wheel horsepower?
Nitrous/blower/turbo?
Street tires/drag radials?
You might want to consider a hardened output shaft.
Old Nov 16, 2011 | 06:01 PM
Gering's Avatar
Gering
Tolero Apto Victum
If it is an auto trans, I would drop the pan and change the filter.
Also here are two good websites for you:
http://rpmtransmissions.com/differentials.html
http://www.centurytransmission.com/home
Good luck with your upgrades.
Old Nov 16, 2011 | 08:16 PM
Tommy D's Avatar
Tommy D
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
St. Jude donor in memory of jpee '14
Since you listed everything but the trans.You might also want to consider upgrading to a Z06 rear and possibly flywheel clutch assembly if you have a M6
Old Nov 16, 2011 | 10:24 PM
os4car's Avatar
os4car
I already had the rpm stage 3 rear end but I had a whine so they are going to change it out for me. I had the 3.73 gears and I am going to go with 4.10 now.
I have 605 rwhp and m6.
I meant anything else to tranny or any other bushings around that area.
Old Nov 17, 2011 | 01:44 AM
Z16chevelleguy's Avatar
Z16chevelleguy
How about upgrading the transmission mounts?
To C6 differential Opinión
