Got "Active Handling recalibrating"
Old Sep 24, 2008 | 08:16 PM
LS WON's Avatar
LS WON
Default Got "Active Handling recalibrating"
What does this mean? This came up on screen while driving. What causes this?
Old Sep 24, 2008 | 09:14 PM
LS WON's Avatar
LS WON
Old Sep 25, 2008 | 07:52 PM
timafey's Avatar
timafey
I randomly get the same thing... I guess as long as your not in mid drift around a corner when its doing that I am guess its ok....
Old Sep 25, 2008 | 09:24 PM
LS WON's Avatar
LS WON
Old Sep 25, 2008 | 09:57 PM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
It happens when you start moving, but go slow and turn a lot. Like when you are leaving a parking garage and have to go very slow and turn a lot. Normal behavior not to worry.
Old Sep 25, 2008 | 10:06 PM
LS WON's Avatar
LS WON
thanks for the info
Old Nov 13, 2011 | 06:41 PM
Batman 357's Avatar
Batman 357
Hey Guys, I got the traction control calibrating warning while going through a solum in the top part of second gear. No other warnings.
Old Nov 13, 2011 | 10:07 PM
KibunInc's Avatar
KibunInc
My cars does this every few months or so and So far I had no problems. I just kinda figured the computer was adjusting my car as needed.
Old Nov 13, 2011 | 11:15 PM
Kwik88's Avatar
Kwik88
Here it is.
http://www.fierolt1.com/lt1_lt4_headflow.htm
Old Nov 13, 2011 | 11:20 PM
Kwik88's Avatar
Kwik88
Sorry, wrong posting
Old Nov 14, 2011 | 01:27 AM
Bill Dearborn's Avatar
Bill Dearborn
No such thing as Traction Control Calibrating.
Active Handling calibrates after each engine start. The car has to be driven in a straight line above a certain speed for a couple hundred feet. This gives the EBCM time to monitor the steering sensor for minimal movement and to check all 4 wheel speeds to see if they are proper for straight line movement (in turns the wheel speeds on opposite sides of the car and from front to rear are different). Once it sees those conditions it remembers the steering sensor output as being the straight ahead condition.
If it doesn't get a situation where it can calibrate within a certain time it displays Active Handling Calibrating.
Bill
Old Nov 14, 2011 | 12:18 PM
taken19's Avatar
taken19
Track Junky
Bill, if this message is displayed from time to time, could it be a sign of potential or intermittent failure? I have developed AH/TC/ABS issues in the past few weeks and remember getting this message several months ago. I'm trying to figure out if it's a wheel sensor, steering sensor, or EBCM issue.
Old Nov 14, 2011 | 06:36 PM
Batman 357's Avatar
Batman 357
I was busy paying attention to where I was going and just noticed the info. MAYBE it was active handling calibrating. I was about half a mile into a fairly tight course. When the run was done I was expecting to see the little tire warning light had activated but all was normal, I guess....
I had one more run and a 30 minute drive home. Everything seems okay.
Old Nov 14, 2011 | 09:24 PM
Bill Dearborn
The message is almost always displayed when the proper condtions to allow calibration haven't been met. Driving through a parking lot can delay calibration due to constantly turning the steering wheel and not hitting the proper speed. Wheel speed sensor would shut down all 3 functions of the EBCM so it probably isn't a wheel speed sensor unless you are getting warning messages for all 3 at the same time. Steering sensor is more AH related but TC does use it as well. The early non AH C5s used steering sensors for TC. Depending on the failure the EBCM can also cause problems for all 3 functions. The only way to know for sure is to get the codes checked with a scanner that can read ABS codes. Can't really do any diagnostics on these cars without knowing the codes.
Bill
Old Nov 14, 2011 | 09:43 PM
taken19's Avatar
taken19
Track Junky
Bill
Thanks Bill.
Are the codes stored? Each time I have gotten the Service AH/TC/ABS messages, they go away when the ignition is cycled. No SES light and my basic scanner will not read them. I took it to Auto Zone but their scanner won't read it either.
Maybe I should take it to my tuner to get to the bottom of it with HP Tuners... Cleaned up all the wheel speed sensors this weekend and tightened up some connections to the frame and the trio of messages hasn't returned yet In 100 miles of driving but I'm not confident that will be a long term fix.
Old Nov 14, 2011 | 09:45 PM
taken19's Avatar
taken19
Track Junky
Oh, and LS WON...
Sorry for the hijack!
Old Nov 16, 2011 | 02:22 AM
CMY SIX's Avatar
CMY SIX
the computer is doing exactly that.
Old Nov 17, 2011 | 10:50 AM
truckplay's Avatar
truckplay
Default happened to me once
the only time that ever came on for me was when i was getting back on the road after leaving a gas station quickly after refueling.
To Got "Active Handling recalibrating"
