Tick master installed stiff pedal?
Old Nov 18, 2011 | 10:20 AM
jbirdblack's Avatar
jbirdblack
Default Tick master installed stiff pedal?
Just had my tick master cylinder installed and the pedal is much stiffer is this normal?
Old Nov 18, 2011 | 11:33 AM
07MontRedcp's Avatar
07MontRedcp
Yes. Some people like it that way, most do not. To bad they didn't mention that to you before the install. There have been several thread recently that discussed this very topic.
http://forums.corvetteforum.com/c6-f...-cylinder.html
BJK
Old Nov 18, 2011 | 11:40 AM
Toxic c6's Avatar
Toxic c6
Dangit I have one waiting to go in. That is the one thing I do not want a stiff clutch pedal it said it will barely increase clutch pedal stiffness on the website.
Old Nov 18, 2011 | 05:52 PM
Joey@Tick's Avatar
0Joey@Tick
Former Vendor
BJK
Suggesting that we hide this information from customers and potential customers is simply incorrect. Our Master Cylinder uses a bigger bore than the stock master cylinder in order to facilitate the many improvements our kit provides. A cylinder using a bigger bore equates to an increase in pedal stiffness.
When our kit is installed and adjusted correctly, the pedal pressure increase will be minor (~15%) with most clutches. It will also be a bit shorter than the factory pedal normally. It will be easier to modulate as well.
The clutch pedal using our kit is a huge improvement over the stock pedal feel - most customers adapt to it and end up falling in love with it in less than a few trips around the block.
Old Nov 18, 2011 | 06:13 PM
07MontRedcp
I think you may be a little to sensitive. My statement of "To bad they didn't mention that to you before the install." was based entirely on the information in the OP's thread title and opening question, nothing more.
BJK
To Tick master installed stiff pedal?
