from what ive read here (I had the same question) the bushings were the difference between the two sets. With the cost of the t1 setup being high, Id opt for an all metal spherical bearing setup like pfadt makes.
That is what I thought. Thanks for the info!
I bought 4 used uppers and was looking to get 4 lowers and install the Pfadt bushings in them after powder coating them so that they are easy to keep clean.
Hey Tim. To affirmatively answer your question, the T1 arms are geometrically the same as the production arms, but with a different rubber bushing designed for a little less deflection.
El Es Tu is spot on. If you were planning on running our poly bushing kit any control arm will do, so long as it's undamaged.
Thanks! I hope be out to see you before Christmas in Salt Lake. Plan to do the Optima events again this year and since I have the rest of your parts on my car, I figured the bushing would be the last piece I needed to add! I have 4 uppers and I took the stock bushing out this weekend and should have the four lowers by next weekend.
Thanks for the order! Let us know how the car is performing after you get the kit installed. The way the weather is looking right now we might not be having a white Christmas around here!
After my first legitimate track day this summer, all I can think about is road race parts now. Luckily I was already running on Pfadt CO's, and could physically see the difference in the leaf sprung cars' cornering characteristcs through undulated sections/turns versus how mine reacted.
I've kind of lost the desire to make more than the 460-wheel I'm making now, and just want more brakes, and more suspension. I'd like to hear your take on 'em.
I did Pfadt Aggressor kit, then brakes (and Pfadt SKF bearings) then the engine.
