Traction: Cost vs Benifit
My little 275/40/17 Mickey Thompson drag radials have traction my 345/35/19 Invos couldn't dream of.
If traction is your goal different compound tires are your answer.
The downside is drag radials are not so hot on turns and are bad in the rain due to minimal siping.
Since you mentioned cornering as well, perhaps you should look into a 305/18 nitto 555R (the road race version). Its a very sticky compound with a slightly stiffer sidewall (than its drag racing counterpart) for traction in the turns.
At Englishtown I staged DEEP and still ran 11.98 @116 mph I am sure if I was shallow staged I would have run 11.95 at least..
I have Nitto 555 Drag Radials, size is 305/35x18 mounted on 2004 OEM rear wheels (thin spoke) they "almost" look the same as my OEM fronts..
My point in this post, I think the OP would be better off using the same tire as I have .. granted if I go to a 3200 converter, I would need more or stickier tire i.e. Mickey Thompson Drag Radials or BFG's
But with the stock converter in my car, it will HOOK every time with Nitto 555 Drag Radials and they can be had from "Discount Tire" for $299 with FREE SHIPPING
I race maybe 2 or 3 times a month during the season March - Nov and ONE set of Nittos lasted me all season...
What I posted is if the OP plans on Drag Racing only NOT road course....or AutoX
I'm SURE after I put on a FAST 102 intake I should see 11.8x with the STOCK Converter...
My thinking is for the car to make a LOT of power AFTER THE 60' so it will be "easy" on parts, it will launch "soft" but PULL STRONG after I'm past the 60' clock.. I'm hoping to run over 120 mph with just adding the FAST intake and maybe a cam that will pull strong after 3000 rpm..
I'm open to suggestions, or criticism, but would like some thoughts on my plan ???
Plan is >> a soft leaving car that will come on VERY STRONG once I'm at the 1/8 mile...
My tires are not the same as the Nitto 555R those are for road course, I'm using the DRAG version..
1. You just bought tires for the street, so no need to discuss that.
2. You want maximum traction for drags.
3. You want to canyon carve. (legal road course track, of course)
A pair of 9.5x17 sawblades or C5 Z06 fronts with Hoosier DR's for the drags.
A set of 5-spoke forged wheels with something like Hoosier A6 tires would stick on the road course.
10 wheels/tires to maximize performance.
You don't wear the same shoes for jogging, hiking, and dancing either.
The car WILL hook with a drag tire. This I know.
The issue is what tires can I run on an 18 ir 19 inch wheel, hit the straightaway in the morning with minimum wheel spin AND be carving corners the same afternoon.
Example: There are several combined events regularly at the local road course's where in the morning you run the long front straight (side by side) for multiple runs (against some pretty high powered GTR's, Porsches etc) and then run the road course later in the day.
I need one tire for both. Swapping wheels/tires back and forth is a PIA and I would have to tow a trailer or transport wheels in another vehicle.
If I spend $3k to install a widebody to mount say a 345 dot approve Mich Pilot SC (or something similar) is the traction THAT much improved? Or is there a tire in a 285-305 size I can run on stock width wheel and hook-up during the side-by-side event and still run around the corners?
I have CCW's now though 19x11 and 18x10, so I'm actually looking to go a little wider with a spacer next time around.
Has anyone tried a 335/30 on a 19x11?
295/35ZR19 for the rear I can mount on stock wheels. Super soft compound with a tread wear rating of 40. I think these might work along with an e-boost.
I use the 325/275 combo as thats the stock Z06/GS tire size. 275 is plenty of tire up front.IMO.
More of them made so they're cheaper and available and suits the C6 just fine. Good enough for me.
