Traction: Cost vs Benifit
Old Dec 1, 2011 | 01:19 PM
DSOMC6's Avatar
DSOMC6
Default Traction: Cost vs Benifit
The cost to go from a 285 to a 325 or 345 rear tire is not cheap.
It looks like it's gonna cost about $2200 by the time I add up the Z06 rear fenders & hardware, paint work, widening the rear 19's and powder coating all four wheels black. This isn't even including the cost of two new fat rear tires (I just purchased two new 285's 3 weeks ago ).
I'm interested to know if there's a big enough improvement in traction to spend the cash?
Plan B was to consider a more sticky tire in the 285-305 range. Currently I'm running a 285 Kumho, detuned to 525whp, and still have to modulate my right foot to keep from over powering the tires. I'm doubtfull however that anything over 550rwhp is going to hook-up in that tire size without a full on drag tire? I don't want to give up canyon carving however. (Yes I want my cake and eat it to).
Is there a less expensive route that will improve traction but not take away cornering? I'll spend the $$ if I can actually hook-up with 580-600whp on a street tire. I'm not expecting to go WOT from a standstill. But would like to keep from going sideways in the mid-upper RPM range. Any imput, thoughts or advice from you folks that improved your straightline traction would be appreciated.
Old Dec 1, 2011 | 01:40 PM
FloydSummerOf68's Avatar
FloydSummerOf68
Which Khumo are you running? There is a HUGE difference between say, a Khumo SPT and a Khumo XS.
SPT has a 320 tread rating and the XS has 180 tread rating and is about the softest street tire made.
If you want/need to stay with a 285 get yourself a Khumo XS, Bridgestone RE-11 or a Hankook R-S3.
No street tire is going to hold in low gears with 525rwhp though.
Old Dec 1, 2011 | 02:14 PM
DSOMC6's Avatar
DSOMC6
Yeh currently have the SPT's on. My goal is to increase the power back to 580whp next week when go back to West Tech (tuner).
I have an A6 tranny so it's not too difficult to keep it straight and from overpowering the tires off the line, but on the 2-3 shift at wot it's a little scary stepping-out at those speeds.
Would a 325 or 345. (say PS2) grip well enough it's worth spending $3k? I'n not looking for cosmetics just want better performance.
Old Dec 1, 2011 | 02:20 PM
Stang's Bane's Avatar
Stang's Bane
You can run 325's without doing a widebody.
Old Dec 1, 2011 | 02:24 PM
SpecialSause's Avatar
SpecialSause
get a stickier tire... hoosier a6, toyo r888
Old Dec 1, 2011 | 02:43 PM
DSOMC6's Avatar
DSOMC6
Have you/anyone done this? There's a pretty good size gap between the fender and tire at stock hight. It would be a bummer to rub consistantly or f-up a fender.
Old Dec 1, 2011 | 02:49 PM
FloydSummerOf68
You're increasing the width, not the diameter.
You can have your 19x10 wheel widened to a 19x11 and run a 325 on it, and yes, people have done it.
Old Dec 1, 2011 | 03:32 PM
DSOMC6's Avatar
DSOMC6
Correct. My concern would be the tire sticking out beyond the fender and hitting the edge/lip over bumps etc. Is the suspension (z51 shocks currently) stiff enough that the several inch gap will be enough to prevent this?
Old Dec 1, 2011 | 03:35 PM
FloydSummerOf68
The tire won't be sticking out much further because you'll be increasing width on the inside of the wheel.
Old Dec 1, 2011 | 03:46 PM
wazslow's Avatar
wazslow
Its not all about the width of the tire either. Alot of getting a car to hook up is in the sidewall. A smaller diameter wheel and a tire with more of a sidewall will hook better than a real low profile tire.
Old Dec 1, 2011 | 04:06 PM
DSOMC6's Avatar
DSOMC6
Gotcha.
This may be a workaround until I purchase/mount wider fenders later next year. It sure would be sweet to upgrade to coilovers rather than fenders at this time.
Old Dec 1, 2011 | 04:18 PM
07MontRedcp's Avatar
07MontRedcp
I noticed a big improvement when I went from 305s to 345s in the rear.
BJK
Old Dec 1, 2011 | 04:27 PM
NYC6's Avatar
NYC6
Widening the stock wheel wont do it for 325's. Just widening the inside will cause rubbing(from what Ive read).
CCW makes several wheels that with the proper offset allow 325/275 tires to be mounted with no rubbing or sticking outside the stock bodywork. They also allow for BBK's, I've had them on my car for almost 3 years now. Mounted are Bridgestone Pole Positions which I like better than the Goodyears. Better traction, less tramlining, longer wearing and less expensive.
You also mention traction with 550+hp and canyons. Are you talking about traction from a dig? If you are then obviously a quality drag radial is needed. If canyon carving, the drags arent as desireable.
I have 522rwhp and the Bridgestones are a nice balance. The car sticks very nicely.
Old Dec 1, 2011 | 04:30 PM
FloydSummerOf68
All you need to do is either slightly trim the inner liner (takes no time at all) or run a 1/4" spacer.
Neither is a big deal and would save the OP TONS of money over the CCWs
Old Dec 1, 2011 | 04:34 PM
DSOMC6's Avatar
DSOMC6
I realize that but don't want to compromise cornering. Trying to ballance-out cornering and straightline traction with a F/I set-up is
Old Dec 1, 2011 | 04:43 PM
NYC6's Avatar
NYC6
How much does it cost to widen the wheels and ship back and forth?
CCW's arent that much(compared to some others) and you get a better, forged wheel. Just one opinion and option.
Old Dec 1, 2011 | 04:46 PM
DSOMC6's Avatar
DSOMC6
I took a quick peak underneath and it looks doable. I just have to figure out how a 265/325 set-up will affect over/under stear and if it can be set-up correctly?
To Traction: Cost vs Benifit
Stang's Bane
I run 325's on the LG wheels. Car is lowered all the way in the rear on stock bolts and no problems at all. I wouldn't suggest trying the Stock Z goodyears though, they are too wide. I run Mich PS2 ZP (Zr1 tires, but in 19") and they are amazing tires.
Old Dec 1, 2011 | 04:51 PM
DSOMC6's Avatar
DSOMC6
BJK
Yeh Bruce that's my ultimate goal next year once funds permit. Did you go wider in the front as well? Have any issues with oversteer?
Old Dec 1, 2011 | 08:33 PM
Ragtop 99's Avatar
Ragtop 99
same here with the 275 upfront. I have nittos; wish I had bought the Re-11s
