How to make back fire
Old Dec 2, 2011 | 11:28 AM
hippypink's Avatar
hippypink
Default How to make back fire
The other posts are about stopping back fire, but lots of Ferraris and Lamborghinis do this, and you could probably consider it a feature.
e.g. http://www.youtube.com/watch?v=v1KN_kOzvVg
Is this something people do to their vettes ever? esp. z06
Obviously, backfire can be accomplished a few ways, some better than others.
Old Dec 2, 2011 | 11:37 AM
MDPD23's Avatar
MDPD23
I pulled the fuse out for the NPP exhaust so they stay open all the time. Down shifting causing the rumbling backfire.
Old Dec 2, 2011 | 12:07 PM
hippypink's Avatar
hippypink
<!-- Cool. Now which fuse is for the NPP exhaust? I just bought a service manual on ebay, but wont get here for a few more days. -->
Nevermind: http://forums.corvetteforum.com/c6-c...-location.html
And video version: http://www.youtube.com/watch?v=uEi6_...eature=related
Old Dec 2, 2011 | 12:33 PM
C7&7's Avatar
C7&7
I just have borla stingers and LG Super Pros.. pops / rumbles like crazy when slowing down or down shifting. Love IT.
hippypink's Avatar
hippypink
K, pulled it. It's in my garage, but really didn't notice any difference in sound. I verified that I pulled the right fuse while looking at the chart (bottom right fuse). Anyways
Old Dec 2, 2011 | 12:57 PM
hippypink's Avatar
hippypink
Considering they are quite affordable, i am thinking about it, although I like the BB exhausts too. Problem is, they look like a lot of work to install. Correct me if i'm wrong
Old Dec 2, 2011 | 01:09 PM
DSOMC6's Avatar
DSOMC6
I love the decel popping and gurgling when pulling up to a traffic light. I get the occasional small fireball out the tailpipe after hard accelleration as well. It's kind of a warning to others (like flashing gang signs).
Old Dec 2, 2011 | 01:16 PM
C7&7's Avatar
C7&7
If you have access to a lift it's a breeze. On the ground in your driveway, not so much. I suppose that's the case with everything though.
Old Dec 2, 2011 | 01:42 PM
el es tu's Avatar
el es tu
gutting the cats or removing totally (as in the case with most headers) allows more fire to escape (and adds power)
Old Dec 2, 2011 | 06:45 PM
haljensen's Avatar
haljensen
Want impressive backfires? Get an older car with a carburetor and a manual trans, run it up in second, turn the key off, pump the gas a few times and then turn the key back on. Can even cause flames to shoot out the mufflers.
Old Dec 3, 2011 | 12:41 AM
SpecialSause's Avatar
SpecialSause
i get lots of pop and rumble with open cutouts... hehehe..
Old Dec 3, 2011 | 11:21 AM
MikeyTX's Avatar
MikeyTX
Veteran: Marine Corps
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
And there may even be some on here that haven't the foggiest of what a carb is.
Old Dec 3, 2011 | 06:05 PM
haljensen's Avatar
haljensen
Then the above setup with a switch, Model A coil and a spark plug in the tailpipe would be over their heads?
Old Dec 3, 2011 | 06:08 PM
saplumr's Avatar
saplumr
Yup...and then plan to replace the exploded mufflers!
Old Dec 3, 2011 | 06:09 PM
MikeyTX's Avatar
MikeyTX
NCM Lifetime Member
Without question.
Old Dec 3, 2011 | 06:43 PM
SeanMo's Avatar
SeanMo
St. Jude Donor '10-'11
Put in 3rd gear, take it to recline, let foot off gas and decel. This makes loudest pops in my car, but I have long tubes and stingers.
Old Dec 4, 2011 | 01:50 AM
CMY SIX's Avatar
CMY SIX
thats not a back fire, thats raw fuel being dumped into the exhaust manifold, a real back fire is a knock on steriods and not cool, you could drill the manifolds and pump gas or propane in, and the everybody would think your a real stud
To How to make back fire
Old Dec 4, 2011 | 09:19 AM
haljensen's Avatar
haljensen
Old school there are two kinds of backfire; a lean backfire thru the intake or a rich backfire thru the exhaust.
Old Dec 4, 2011 | 09:24 AM
MikeyTX's Avatar
MikeyTX
NCM Lifetime Member
Also effect depends on if one eats at Taco Bell or lessor known venue ...........
Old Dec 4, 2011 | 10:21 AM
haljensen's Avatar
haljensen
A belch or a fart is still passing gas?
Can you light a belch?
