C6 Cold Weather Shifting
Old Dec 4, 2011 | 02:46 PM
TimSweet's Avatar
TimSweet
Cruising
Default C6 Cold Weather Shifting
My '07 C6(manual 6 speed) just will not shift in cold weather. Now, I'm talking about Southern Arizona cold weather, we aren't talk -20 degrees or even 0 degrees.
Under 60 degrees it hard shift, lower than 50 degrees, and it just won't shift at all. I'm having to place the car in the gear I need to leave the parking spot in (first or reverse) just to get it moving, after a while it loosen back up.
I've been told "well that's just the nature of the beast" to which I call BS!!
I'm using the Dot4 GM clutch fluid.
Is there anything I can do? Different fluid?
Thanks for any suggestions.
Tim
Old Dec 4, 2011 | 04:41 PM
timd38's Avatar
timd38
Try RedLine. My shifts fine since I changed to it.
Old Dec 5, 2011 | 11:37 AM
TimSweet's Avatar
TimSweet
Cruising
Thanks I'll give it at try.
Old Dec 5, 2011 | 12:24 PM
LEAVINU's Avatar
LEAVINU
We should be talking about tranny fluid here not the clutch fluid you mentioned in the first post.
I had zero cold fluid issues with Royal Purple Syncromax for years. I switched over to Amsoil tranny fluid and find its very rough when cold then smooths out as it warms up. Not sure what I'll do when it comes time to change again.
Old Dec 5, 2011 | 02:58 PM
Ragtop 99's Avatar
Ragtop 99
I switched to redline D4 and it helped reduce the ambient temp when notchiness occurs by about 10*.
If the car will truly not shift at temps in the 40's, the issue is more than fluid. It's mechanical.
To C6 Cold Weather Shifting
