Maintenance question
Old Dec 12, 2011 | 07:39 PM
mrtian97's Avatar
mrtian97
Default Maintenance question
I have 07 MN6 Coupe, 1LT, with 8,200 miles. Car is 4 years old, so far only have Oil change once per year.
What all the fluids that I should replace? Clutch, Transmission, Coolant, anything else? Which brand to buy?
Car running fine, just not driven much.
Thanks for all the input
Old Dec 12, 2011 | 08:23 PM
RicK T's Avatar
RicK T
The "general", stress "general", recommendations are:
Change oil when the Oil Life Monitor says to, OR once per year regardless of mileage;
Clutch fluid as needed to keep it clean looking in the master cylinder, usually a couple times a year, some do it as often as every month or more often, depending on driving, use and appearance. Follow the "Ranger Method" to do it with a turkey baster from the master cylinder;
Brake fluid every 2 years;
Coolant every 5 years.
Old Dec 13, 2011 | 04:46 PM
Eric D's Avatar
Eric D
St. Jude Donor '09-'10-'11
If you are noticing any shift issues, gear nibble, or grinding I would change out the trans fluid too. The fluid degrades with time; yours has over 5 years on it. For the money it is a cheap preventive measure.
Old Dec 18, 2011 | 04:56 PM
AYello1's Avatar
AYello1
I changed my '07 OE differential oil at 10k. Used the latest GM recommended fluid # 88862624 Dexron LS. It made a huge difference! Pricey ($35.00 a quart), but worth it.
Old Dec 19, 2011 | 08:50 AM
Ketchum's Avatar
Ketchum
5 year coolant.
Old Dec 19, 2011 | 01:57 PM
truckplay's Avatar
truckplay
Default I have a 05 m6 with 30k
I change the brake & clutch fluids every year (hydroscopic) oil every 5k. Last weekend I changed diff, trans & coolant 30k.
To Maintenance question
