Keeping Battery Charged
Old Dec 13, 2011 | 03:11 PM
acev6's Avatar
acev6
3rd Gear
Default Keeping Battery Charged
I parked my 2010 Vette for 3 weeks.... the battery was flat... I charged the battery and all was fine... I parked for 2 days.. the batter was dead again... my local Chev dealer tells me that the battery is only good for 16 days with the draw on it.... and creates a memory and now won't completely recharge... I will only drive the car periodically over the winter... the car is parked inside but there is no power to leave a charger on it... how can I maintain the battery without disconnecting it??
I would be interested to hear how others store their Vettes without power... I was looking for a portable battery pack with a trickle charge on it... anyone know of any available ... all information will be great-fully received
Old Dec 13, 2011 | 05:51 PM
el es tu's Avatar
el es tu
any time youre leaving the car out for an extended period take the battery out and charge it somewhere with power
Old Dec 13, 2011 | 06:30 PM
marc8090's Avatar
marc8090
Many use a battery tender whenever the car won't be used for an extended period of time. Unless I know for certain I'll use the car in the next couple days, I plug it in.
Old Dec 13, 2011 | 06:40 PM
JoesC5's Avatar
JoesC5
You either have to run a heavy duty weather proof(outdoor) extension cord to the storage area and connect a float charger to the car, or remove the battery and take it inside.
Old Dec 13, 2011 | 07:00 PM
joliett's Avatar
joliett
I use a solar battery recharger I bought cheap at Harbor Freight.
Old Dec 13, 2011 | 08:21 PM
StKnoWhere's Avatar
StKnoWhere
Default Priority Start
A Priority Start will disconnect your battery automatically when the voltage drops below 12.5 v.
Pushing in the cigarette lighter makes it reconnect and there should be enough charge to start the car.
Make sure you know how to access the car via trunk key since the doors will not unlock.
Old Dec 14, 2011 | 11:31 AM
John Harry's Avatar
John Harry
St. Jude Donor '10-'11-'12-'13-'14
Give the battery a long 2 amp charge (don't try to charge it by driving it), then get it tested to see how well it holds a charge. Replace if necessary - might still have some warranty left on it.
As an alternative to removing the battery or using a Priority Start, just remove the negative cable. Make sure you can get into it without power, and re-index the windows when starting it up again.
Old Dec 14, 2011 | 12:39 PM
turboffr's Avatar
turboffr
St. Jude Donor '10
I'd try to avoid disconnecting it if possible. I did that with mine while I was working on it and now the car does not recognize the key fobs. I need to start the car with the fob in the glove box. All the research I've done seems to be that when the battery goes dead or is disconnected, this issue can happen. Seems silly to me, just from disconnecting the battery. Never happened in my '06, but first time I disconnected the battery in my '08 it caused this issue.
Old Dec 14, 2011 | 08:45 PM
MikeSVT04's Avatar
MikeSVT04
just hooked up a battery charger/maintainer from harbor freight today...24.99 shipped.
took 5min or less to hook up. I put the charger on a glass cutting board in the back hatch, just in case it got hot or something...
So far so good.
Old Dec 15, 2011 | 06:32 PM
Bill Dearborn's Avatar
Bill Dearborn
My 08Z was built 4 years ago and put in service on Feb.20th or so of 08. It is still on the original battery sits in a cold garage and has always been able to start the engine after sitting for 4 to 5 weeks. It sat for 6 weeks waiting to get a new engine earlier this year and seemed to handle that situation well. Will know soon whether or not it still has the capability to do that. Will be letting it sit in the cold for 3 plus weeks.
Bill
Old Dec 16, 2011 | 11:37 AM
craftsman74066's Avatar
craftsman74066
Bill
My 07 has the orginal battery and works well after 3-5 weeks.I know i am playing with fire but can'pull a batt. that still works.
Old Dec 16, 2011 | 03:01 PM
Streetk14's Avatar
Streetk14
Do you have any aftermarket parts on the car? My '08 only has around 20 ma draw after all modules enter their "sleep" mode, which is pretty good. But if I leave my exhaust controller in the quiet mode, the draw goes up to 350 ma - which will kill a healthy battery in a few days. Fwiw, most new cars with a lot of electronics have a ~50 ma draw specification.
And yes, a battery that has been fully discharged will never be 100% again. So stay on top of keeping it properly maintained and have a draw test done for good measure.
Old Dec 19, 2011 | 10:42 AM
acev6's Avatar
acev6
3rd Gear
Thanks for all the advice... the car is under warranty.. it is only 9 months old.. so I am will be taking it to the dealer. The car is garaged but I cannot plug it in... I did buy a jumpstart box to allow me to get the car running... Thanks again for all the help
To Keeping Battery Charged
