Changing filter element in Callaway Honker
Old Dec 24, 2011 | 11:11 AM
beepster's Avatar
beepster
Default Changing filter element in Callaway Honker
Need help in changing the filter element. I removed the 4 **** screws that appear to be holding the assembly together but still can't get it apart. I don't see anything else holding it together. Front visability limited because of the hood and radiator. ????
Old Dec 24, 2011 | 03:18 PM
chpdbp's Avatar
chpdbp
Disconnect it from the throttle body also. Once that is done and the four **** style screws are loose, that's it. It might get a little stuck just from hot & cold extremes. Just gently pry it and eventually it will pop loose. I know there is not a lot of room to work. I double checked mine just before I sent this to make sure. Good luck and Merry X-mas.
Old Dec 24, 2011 | 04:15 PM
beepster's Avatar
beepster
Thanx for the reply...we'll try the total disconnect. Merry Xmas to you too!
Old Dec 24, 2011 | 04:49 PM
ErnieN85's Avatar
ErnieN85
you have to slide it up as there are two pegs at the front instead of screws, so disconecct the air bridge, remove four screws, then slide up the shroud till the pegs unhook.
Lift it out
To Changing filter element in Callaway Honker
