Clunking from rear when turning
Old Dec 26, 2011 | 07:03 PM
08Z51's Avatar
08Z51
Default Clunking from rear when turning
I have a 2008 Z51 with 7500 miles. It has never been raced or really driven hard. I am now getting a clunking noise coming from the rear when I turn, either direction. I hear/notice it at low speeds. Anyone know what is causing this and if it will be covered under warranty?
Old Dec 26, 2011 | 07:09 PM
10mikeymike's Avatar
10mikeymike
Do a search. It's your rear differential. There's a quick and easy solution.
Old Dec 26, 2011 | 07:26 PM
marc8090's Avatar
marc8090
While that's a possibility I wouldn't say it's an absolute. Could also be sway bar end links or axle nuts.
Old Dec 26, 2011 | 07:40 PM
haljensen's Avatar
haljensen
Call your Dealer service dept and complain of the noise. Ask for Warranty service (the fluid change to the new differential fluid). There was a Tech bulletin about it . With luck they'll do it under Warranty, no luck and you'll have to pay for it.
Worked on my '08 in 2010.
Old Dec 27, 2011 | 08:02 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Mine was the endlinks. Went through two sets of them till GM came out with a new replacement model of them. No more issues after that.
Old Dec 27, 2011 | 09:59 AM
Chevy Cust Svc's Avatar
Chevy Cust Svc
08Z51,
Getting your rear differential fluid changed may resolve the issue. However, this is something that may not fall under your warranty coverage as it's technically a maintenance service. I would recommend contacting your dealership and trying to work with them to resolve the issue. I'd be more than happy to contact them for you.
Chevrolet Customer Service,
Justin
Old Feb 2, 2012 | 10:22 AM
mario7669's Avatar
mario7669
bump
im having the same issue on my 08 car only has 31k has what is the solution????? clunking noise when turning at low speeds
Old Feb 2, 2012 | 12:33 PM
mikeCsix's Avatar
mikeCsix
I believe there was a TSB on this with regards to changing the differential fluid. The new fluid had friction modifiers with it, replacing the fluid in my '08 Z51 cured the problem, what I heard was a clunking from the rear end, in the morning when first starting out (cold differential), apparently the clutches in the rear end have a tendency to stick together when cold so that first drive in the AM would break them loose as I turned out of the driveway (I back my cars in). When the dealer replaced the gear oil, they drove in tight circles to fully lubricate the differential (figure 8's a couple of times). Numerous posts regarding this if you want to do the procedure yourself.
Old Feb 2, 2012 | 02:15 PM
flyinryan87's Avatar
flyinryan87
I had this issue a few years ago.. Swap out the fluid in the differential. I tried royal purple.. and that solved it for a month.. Then swapped it with Amsoil severe gear, and a tube of the sliplock additive.. been smooth and no clunking/differential noise for over 2 years now..
Old Feb 2, 2012 | 08:02 PM
timd38's Avatar
timd38
I changed to Redline oil and the noise went away.
Old Feb 2, 2012 | 08:07 PM
littlejohny's Avatar
littlejohny
8th Gear
2007 A6
Mine had the problem, one dealer (Munday) said it was NOT warranty (fluids) but another dealer (Tomball) said it WAS warranty and changed the fluid no charge. Problem solved.
Old Feb 2, 2012 | 08:12 PM
v26278's Avatar
v26278
My '07 had a popping/grinding noise during low speed turns, the fluid change fixed the problem. It was most noticeable when cold, usually went away when the vehicle warmed up.
Old Feb 2, 2012 | 08:14 PM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
AMSOIL Severe Gear Extreme Pressure Synthetic 75w90 (Product Code SVGQT)
AMSOIL Slip-Lock Differential Additive (Product Code ADATB)
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Old Feb 2, 2012 | 08:43 PM
TexasGuy75104's Avatar
TexasGuy75104
Had the same problem. Changed the differential oil and problem solved.
Old Feb 2, 2012 | 10:01 PM
mario7669's Avatar
mario7669
Originally Posted by Subdriver
how many quarts??
Old Feb 3, 2012 | 05:05 PM
C66 Racing's Avatar
C66 Racing
Originally Posted by mario7669
how many quarts??
C6 diff takes about 2.7 qts.
Old Mar 6, 2012 | 09:01 PM
SeeSixer's Avatar
SeeSixer
Just had the same issue with my '08 Z51 w/11K miles. Took it to my local dealer - they changed the diff. fluid at no charge and that took care it.
To Clunking from rear when turning
Old Mar 7, 2012 | 02:04 AM
JCtx's Avatar
JCtx
Having the same issue with my brand new '12 GS MZ6 with only 10 miles on the clock, so it's got to be normal. Or at least not a problem . Thought I clipped something when turning full lock to clear the trailer's ramp. Drove it the mile home and haven't touched it due to lack of documents. Just got the MSO today, so will get the plates tomorrow. I plan to make a few figure 8s; that's supposed to make things better. If not, then I'd change the fluid. You'd think GM would be putting the good stuff by now .
I plan to use Royal Purple. But what's the viscosity? 75/90 or 75/140? Put RP MaxGear 75/140 on my M3 and it fixed the moaning. I also put RP Synchromax in the tranny and made a big difference. Do our trannies use Synchromax too? And how many quarts in the tranny? My GTO took 4.6, but it was the T56. Our TR-6060 should be the same or pretty close. Thanks gang.
Old Mar 7, 2012 | 07:55 PM
truckplay's Avatar
truckplay
i read here the other day that someone found their engine cradle loose. they were also chasing a noise. there are also many that found the sway bars & links to be causes for noises.
Old Mar 8, 2012 | 10:11 AM
haljensen's Avatar
haljensen
Probably NOT the differential.
Most likely the front tires scrubbing at full lock slow speed turns. There is no solution other than don't do full lock turns, it's a function of the design of the steering geometry and wide tires. It's present in all C6's.
