I am installing my Kook headers and X-pipe however, my 2008 corvette is not allowing me to remove the factory Xpipe easily from the stock NPP mufflers. I have removed the factory manifolds and cats although, with both of them removed the Xpipe will not come lose from the mufflers at all.
Clamps have been loosened, and the xpipe mid section nuts that hold it on the springs are removed. It's currently soaking in WD40; I have a plastic hammer that I have been using to hit the jointed area however, no success as of yet.
Has anyone had this issue, and do you have any suggestions to remove the factory Xpipe from the NPP exhaust? I am on jack stands in my garage and, I'm worried I will need a torch to get the job done.
Please tell me I'm missing something simple because I have not found one thread where someone was having the same issue.
Those can be extremely tricky it they have been undisturber for a while. The trick is to soak in a penetrating fluid and slowly working back and forth until they let go. No other way that I can think of.
Just took the h-pipe off my 2006 yesterday. I had a hard time as well and wondered wth?? I'd never seen anyone with an issue before. Like you, I just committed to a lot of pushing and pulling and then I finally saw some movement. For a while there, I thought it had a small weld somewhere that I couldn't see. I thought I was going to trash my mufflers with all of the yanking, rocking and pounding I was doing to it. The over axle pipes from the mufflers were moving all over the place and being under the car, I couldn't really see what the mufflers were doing
Oh well, glad to hear I'm not the only one... I always learn a lot about the car everytime I try something on it.
