Car problems
Old Jan 2, 2012 | 10:56 AM
nicholasisle's Avatar
nicholasisle
Default Car problems
I have a 2005 c6 and almost once a day i will be driving down the highway and it will die. After i pull over and wait a minute i start it back up and it runs fine. It always says service traction control when this happens. I have scanned it and nothing comes up. Any advise or suggestions will be greatly appreciated thanks.
Old Jan 2, 2012 | 11:22 AM
calemasters's Avatar
calemasters
I would use a data recorder to see what is happening at the time of the stall.
Old Jan 2, 2012 | 11:30 AM
Kenny94945's Avatar
Kenny94945
I think the only thing you can do is insure your battery cables - both cables both ends are secure.
No codes - oh boy. Battery disconnect wiping codes?
Cales above is the way to do it. Short to one of the computers? Ignition switch issue?
Old Jan 2, 2012 | 12:18 PM
C7&7's Avatar
C7&7
Is it a new battery? Possibly get it and the alternator tested. Does the DIC go dead when the car dies, or does the car stay powered and just die? If it stays powered then it sounds fuel related. Check the fuel pump relay in the fuze box under the hood. Check to see if it has any dark drown marks on it.
If the DIC dies also with the car then it's power related. Battery, alternator, etc.
Old Jan 2, 2012 | 01:36 PM
Chevy Cust Svc's Avatar
Chevy Cust Svc
nicholasisle,
If you've checked your battery and connections I'd recommend leaving it with your mechanics over night and have them try and replicate the problem. Let me know if you'd like to recommend a dealership.
Chevrolet Customer Service,
Justin
To Car problems
