I'm trying to find a good crank damper for my 07 c6. Mine is wobbly.
What websites are best?
Thank you
Few years ago, ATI did not believe UD provides enough damping for our engine and not until the demands from drag racing crowd that ATI finally mfg the UD along with the standard size.
Something to think about whether that 5 hp is worth the risk! HTH!
Find the threads of all the people who have had a failure due to an UD pulley.
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
There are a number of balancers out there.
We have used ASP and SLP balancers and have never had any issues with their products.
The ATI balancers are probably the best on the market for the LS engines. Do keep in mind these are race balancers and do require service. They will give you a service interval with the balancer whne you get it. Typically for street use they need to be rebuilt every 5-10 years depending on use.
