FOB programming hints
Old Jan 6, 2012 | 09:29 AM
vintagez's Avatar
vintagez
Default FOB programming hints
Saw a bulletin referring to FOB programming problems on some of the other new GM vehicles, but maybe these points could also apply to our vehicles, hope it helps. Again these are hints if you are having problems programming a FOB:
6. The key fob is not positioned properly within the fob programming pocket .
Depending on the number of keys attached to the key ring, the key fob may not sit properly in the key fob pocket.
7. Avoid low frequency challenge interference during fob programming.
Normal activations of the keyless access functions will result in activation of low frequency communication within the vehicle. This communication is at the same frequency and is generated from antennas located in proximity to the communication which is used to program key fobs and can interfere with the vehicle’s ability to successfully program the fob.
In most cases, this will not damage the key fob and the programming process can be attempted again. However, in a worst case scenario, a low frequency challenge at the wrong time of the learning process can prevent the key fob from being programmed to any vehicle.
- Do not pull the door handles or attempt to open the doors.
- Do not touch the lock sensors on the door handles.
- Do not close the last door (i.e. keep at least one door open during programming).
- Do not unlock the door through the driver door key cylinder.
- Do not open the trunk.
Tip
While unlikely, it is possible that other vehicles that transmit low frequency challenges can also cause interference in the programming process
While these may not all apply, maybe it can be of help.
Old Jan 6, 2012 | 02:55 PM
MIGHTYM0USE's Avatar
MIGHTYM0USE
i have a fob that doesnt work, but when i put it in the pocket and go through the sequence, it says 'fob already programmed' or something to that effect.
the battery is good, and also if i try to use it to start the car by putting int in the pocket as if it is a dead battery, nothing happens.
ideas?
Old Jan 6, 2012 | 05:32 PM
turboffr's Avatar
turboffr
St. Jude Donor '10
Same thing happened to me after I disconnected my battery. "NO FOBS DETECTED". Changed the fob batteries same thing. Then tried to reprogram the fobs and DIC said "known FOB". I then went through the long reprogramming sequence and the fobs still don't start the car unless I put one in the slot. Battery checks out. At this point I think I need the dealer to reprogram them.
Old Jan 19, 2012 | 12:22 PM
MIGHTYM0USE
turboffr, any luck?
Old Jan 19, 2012 | 06:41 PM
turboffr's Avatar
turboffr
St. Jude Donor '10
Originally Posted by MIGHTYM0USE
turboffr, any luck?
car is put away for the winter so I haven't done anything with it yet. I'll let you know
Old Jan 21, 2012 | 07:17 PM
MIGHTYM0USE
just wanted to follow up these threads with my solution
new energizer 2032 battery (no dimples on - side)
works fine!
this is after trying 2 other GOOD dimpled batteries, so my suggestion is if you have on fob that works, and one that doesn't... swap batteries real quick to find out.
thank god! now onto figuring out the seat heater fuse blowing all the time.. then its perfect.... oh and the seat retractor rattle and uh... jk
Old Jan 21, 2012 | 07:24 PM
turboffr's Avatar
turboffr
St. Jude Donor '10
works fine!
did the dimple batteries still work the door locks, but just not start the car?
Old Jan 21, 2012 | 09:17 PM
MIGHTYM0USE
The only thing it would do with the other batteries was start the car while in the pocket
To FOB programming hints
