2007 z06 ecm location
Jan 9, 2012 | 08:54 PM
i really need to see a photo of the ecm bolted to the pass. fender. i for the life of me cant figure it out plz someone help with a photo
Jan 9, 2012 | 09:30 PM
Jan 10, 2012 | 10:52 AM
St. Jude Donor '07-'08-'09-'10-'12-'13-'14
Thanks Pal!
Quote:
Originally Posted by
RicK T
Thanks Pal!
Chuck CoW
Mar 11, 2014 | 06:58 PM
Chuck CoW
Thanks Pal!
Chuck CoW
Except the link is to a picture of a regular C6, not a Z06. Any pictures available of what was asked for, a Z06?
Mar 16, 2014 | 03:35 PM
The ZO6 is slightly....
MIZR1
The ZO6 is slightly different. If it's an 08 and earlier Z then the PCM is just behind the dry sump tank
and it's accessible just the same as the regular C6 from the same method but you just have to get in there
a bit further with your hands.
If it's ANY Corvette after 2009 then the pcm sits up high in the fender just above the opening in the fender well.
You access it just the same as the earlier C6 outlined in the above links, but you should have the vehicle
just a bit higher up off the ground to make it easier to reach up there.
Call me if you're stuck.
Chuck CoW
07 ,
2007 ,
2008 ,
c6 ,
change ,
corvette ,
ecm ,
ecu ,
located ,
location ,
remove ,
z06
