Slave cylinder problem
Old Jan 12, 2012 | 12:01 AM
lilmiller74's Avatar
lilmiller74
Default Slave cylinder problem
On my old slave cylinder on my 05 vette the ruber line some how all of ths suddin started hitting my header and caused it to burn a hold in it. So I went threw all the work and replaced the slave cylinder and made sure that the line was up and away from the header and took it for a drive and it slid down and hit the header again and melted. Is there any way that this ruber line can be replaced with a steal braded line or is there a way to replace that line instead of going back threw all the work and buying another new slace cylinder?
Old Jan 12, 2012 | 09:37 AM
taken19's Avatar
taken19
Track Junky
Did you use anything to secure the line out of the way like a zip tie. You shouldn't take the chance with tucking it up under something and walking away. You could also put some heat shield over the rubber line.
Old Jan 12, 2012 | 11:37 AM
07MontRedcp's Avatar
07MontRedcp
Here is how APS modified the slave line for their install. Scroll dow to steps 13-15.
http://airpowersystems.com/corvette/...tall_guide.htm
BJK
To Slave cylinder problem
