Lifter preload cross reference
Old Jan 12, 2012 | 03:37 PM
o1Z0sick's Avatar
o1Z0sick
Default Lifter preload cross reference
I have some spefications for various GM lifters with part numbers, but I have a lifter part number in my build that is not listed in the table. As seen in the table, different lifters have different preloads. I have the 12499225 LS7 lifters so can anyone verify if these are the same specs as 17122490?
Old Jan 12, 2012 | 03:47 PM
o1Z0sick's Avatar
o1Z0sick
I think I have found the answer but please verify. 12499225 is the set of 16 and the individual lifter is 17122490.
Old Jan 12, 2012 | 05:13 PM
PartsTaxi.com's Avatar
0PartsTaxi.com
Former Vendor
That is correct. I just grabbed one off the shelf to verify. 12499225 is the set of 16 of 17122490 lifter.
Kevin
www.PartsTaxi.com
Old Jan 12, 2012 | 05:51 PM
carlrx7's Avatar
carlrx7
St. Jude Donor '08-'09
So with the 1.25m rocker bolt, 1 and 2/3's turn from zero lash would equal the perfect amount of preload.
-Carl
Old Jan 17, 2012 | 12:04 AM
o1Z0sick's Avatar
o1Z0sick
Great thanks, this helps a lot. 1.66 turns it is. The 12499225 is qty 16 and 17122490 is qty 8 but where it had me confused is that 17122490 is also qty 1, it's just not listed to purchase as qty 1.
Old Jan 17, 2012 | 07:40 AM
Eric D's Avatar
Eric D
St. Jude Donor '09-'10-'11
Just want to make sure you understand that you DO NOT set lifter preload with the rocker hold down bolt. The bolt needs to be torqued to 22 lb ft, fully seated. Only torque the rocker hold down bolt when the lifter on the base circle of the cam lobe.
If there was component changes from stock, the rocker to valve stem wipe pattern should be checked and change pushrod length if needed to obtain the proper preload.
Old Jan 17, 2012 | 07:39 PM
phkned's Avatar
phkned
Can I ask why the lifter preload is so much when every performance engine I and everyone I know build have just 1/4 turn of preload on hyd lifters to prevent pump up?
Old Jan 17, 2012 | 08:05 PM
carlrx7's Avatar
carlrx7
different lifters require different preload.
Old Jan 17, 2012 | 08:23 PM
Eric D's Avatar
Eric D
Lifter preload has nothing to do with or preventing lifter pump up.
Old Jan 18, 2012 | 06:23 AM
phkned's Avatar
phkned
No it does not cause it but if you only have about .020 in preload from the pushrod then it can only pump up that amount not the .200 or so it says to put in.
If lifter preload amounts don't contribute to pump up then what does?
Pump up is caused when the lifter loses contact with the cam lobe and the lifter fills with more oil then it would normally have to fill the extra space made by the lost contact with the cam. When the lifter regains contact with the lobe the extra oil can't get out fast enough and the valve stays open. This is why you don't see this problem with solid lifter motors.
Old Jan 18, 2012 | 09:47 AM
Eric D's Avatar
Eric D
Without going through the details of valvetrain dynamics, in brief, a properly designed valvetrain system allows the valves to open and close at their precise timing points, maintains track of the cam lobe to a given maximum engine rpm. To do this, it is a balance of valvetrain component mass, valve spring, cam lobe lift profile and engine operational rpm.
Valve float is the single cause of lifter pump up. The definition of float is simple, it is when the valvetrain is forced pasted its design parameters. Changing a single component in the valvetrain system can cause a change in the dynamics and lowering the rpm that float occurs.
The valve spring is a key component in the system. The valve spring’s job is to store enough energy to return all components, and keep all in sync and back to the base circle of the cam lobe. As engine rpm increases, so does the inertia mass of the valvetrain components. As this occurs there is a point where the spring doesn’t have enough stored energy to complete its job and the valvetrain components go out of sync. When this happens the loading on the hydraulic lifter will reach a point that its internal spring will force the lifter to do its job of trying to take up free space. This is known as valve float.
The same thing can and does occur regardless if the engine has solid or hydraulic lifters.
You are not changing the valvetrain dynamics by using less preload on the lifter. This only limits the effective range that the lifter can compensate for valve seat erosion and normal thermal growth of the engine. Not a good thing in my opinion. There are real and better ways to insure the proper operation of the valvetrain for the given application other than messing with the preload of the hydraulic lifter.
The numbers given in the table in the first post of this thread are the proper preload for the part number lifters given. Setting up with anything else does nothing to improve valvetrain system dynamics.
Old Jan 18, 2012 | 10:43 AM
o1Z0sick's Avatar
o1Z0sick
I agree with Eric. It is important to understand the check ball and spring inside the lifter rely on the equations of motion for reciprocating motion (acceleration and mass) during normal operation. When valve float occurs all this goes up in tire smoke The deceleration of the lifter during the cam lobe lift does not begin at max lift but occurs after allowing to much oil into the plunger cavity. Valve float negates smooth closing as well so the lifter will usually bounce on the closing lift cam lobe. This bounce will allow the check ball to come off seat allowing even more oil into the plunger cavity.
Think of the hyd lifter as the dampener for you suspension. It is good to have it's stroke half of max at normal ride height.
Old Jan 18, 2012 | 07:37 PM
phkned's Avatar
phkned
Guy's I totaly understand how engines work I am an engine machinist and have built racing heads for over 14 yrs. I appreciate the thought in trying to help me but all you did was just explain the very same thing I said in another way. You did not answer the question of why this LS lifter needs so much preload other then to say that is what Chevy says to use in simple terms.
It is not the spring in the lifter that causes it to fill with oil during valve float,it is the oil pressure. The spring is only strong enough to hold the pushrod snug when not running.
Btw just let me say if you do have .020 of of seat or valve erosion you have much bigger problems then the lifter preload. It's time to tear down when you lose that much lash.
Old Jan 18, 2012 | 08:38 PM
Eric D's Avatar
Eric D
With all your experience I’m sure you know more than all the engineers at GM. Carry on with doing it your way.
Old Jan 18, 2012 | 09:32 PM
carlrx7's Avatar
carlrx7
you are referencing inches, and we are talking mm like the table displays.
ls1tech shows .100 - 0.80 as the prefered preload . the 2mm = 0.080mm btw
-Carl
Old Jan 18, 2012 | 10:12 PM
phkned's Avatar
phkned
Eric if you dont know the answer other to say thats what the factory says then thats fine, just say so. You dont need to be an ******* and insult me.
Old Jan 18, 2012 | 10:23 PM
phkned's Avatar
phkned
-Carl
Carl thank you i looked at the chart very quickly and just did a dyslexia job on it,lol.
But either way the distance is really irrelavent to my question since in reality i have never bothered to measure how much depresion 1/4 turn was anyway and used .020 just as a reference value.
I understand why Chevy does this because they want the motor to run no matter how much wear is in the valvetrain but I cannot understand why anyone else building an LS would.I would just use a slightly shorter pushrod to get the geometery correct and do 1/4 turn.
To Lifter preload cross reference
Old Jan 18, 2012 | 10:30 PM
phkned's Avatar
phkned
You mean the very same engineers who are responsible for all the LS7 dropped exhaust valves? Or the engineers who designed the targa roofs that seperate? OH maybe you are talking about the ones who designed the diff in 05's.....
Old Jan 19, 2012 | 12:51 AM
bosco 08's Avatar
bosco 08
I'm getting confused here so maybe someone can answer this question. What's the proper procedure for preloading lifters on an LS3 and how many turns are needed?
Thanks in advance.
Old Jan 19, 2012 | 07:25 PM
Eric D's Avatar
Eric D
Thanks in advance.
All stock LSx engines are set the same way, including the LS3. With the lifter on the cam lobe base circle the rocker hold-down bolt is tighten to 22 lb ft. If this is something you are planning to do, having the service manual is a good idea.
