Cammed Corvette reliable?
Old Jan 13, 2012 | 06:30 PM
envyz06's Avatar
envyz06
Default Cammed Corvette reliable?
I am looking at a corvette for sale that has a cam installed. Owner says a shop installed it and has only 2500 miles on the cam. The car has 67k miles. Should I be worried about anything? I have had a cammed LS1 Camaro and that gave me no problems. LS2 M6
This is the Cam
"TR TRuTorq" Level 4 - 227/234 .616/.614 115 LSA 2200-6800 RPM Power Band
Dual Patriot Gold Valvesprings and Ti Retainers
- Thunder Racing Pushrods (7.400)
- Valve Stem Seals
Any thoughts? Thanks
Old Jan 13, 2012 | 06:54 PM
mitchell c's Avatar
mitchell c
Is the car M6 or A6. Is the engine an LS2 or LS3?
Old Jan 13, 2012 | 07:41 PM
envyz06's Avatar
envyz06
updated LS2 6 speed sorry
Old Jan 13, 2012 | 08:29 PM
LS1LT1's Avatar
LS1LT1
Yes.
Any thoughts?
As long as it was installed properly and everything was put back together/torqued (and also tuned) correctly then it should be reliable/dependable.
Old Jan 13, 2012 | 09:24 PM
Nightstalker Medic's Avatar
Nightstalker Medic
I'm a cammed M6 LS2 and I have no issues.
Do it
Old Jan 14, 2012 | 10:28 AM
C7&7's Avatar
C7&7
Originally Posted by LS1LT1
Yes.
I would want to find out where the cam was installed and tuned if I were buying it. Just for my own curiosity.
Old Jan 14, 2012 | 11:14 AM
99blancoss's Avatar
099blancoss
Former Vendor
St. Jude Donor '10-'11-'12
depends on the tune and the agressiveness of the cam lobes, how well the valvetrain was setup and how beat on it is..
Old Jan 14, 2012 | 11:36 AM
envyz06's Avatar
envyz06
Sounds like it should be alright. He told me this is the shop that did everything, Corvette Speed Shop, Jamisons Corvette. Anyone heard of them? It will probably be my daily driver for a little while but I only drive about 3-4 miles to and from so wont be bad I am thinking.
Old Jan 14, 2012 | 07:30 PM
needcheese's Avatar
needcheese
I have had no problems with the LG G6X3 cam installed in mine. I close to 20k miles on the cam. The only thing I had to do was replace the valve springs. This is recommended to do between 15k-20k miles on large lift cams.
Old Jan 14, 2012 | 10:47 PM
EricT's Avatar
EricT
I would want to know why he was selling so soon after the mod.
Old Jan 14, 2012 | 11:17 PM
S'vette's Avatar
S'vette
when doing a street cam do you need to get the new valve springs and all or will just the cam and the same acc parts be ok?
Old Jan 14, 2012 | 11:38 PM
LS1LT1's Avatar
LS1LT1
It probably depends on the size of the cam, but it would have to be quite small/close to stock in order for one to keep the stock springs and still remain on the safe side.
Either way it's still a good idea to put at least a 'light duty' aftermarket spring (or even an upgraded OEM spring like from a C6 Z06) in there when doing the swap.
In the old LS1 days, people often upgraded to the LS6 cam and did so because they were cheap to buy and didn't necessarily mandate a spring swap, but even there I personally would still choose to upgrade.
Old Jan 15, 2012 | 01:58 AM
winters97gt's Avatar
winters97gt
Even with adding a LS9 cam to my car, I upgraded the valvetrain. I don't really see a point in not spending a couple extra hundred bucks for peice of mind.
OP, do it. Those cam specs sound great for a street car. The 115 will have a slight lope to it, but nothing too radical. A good tune and it should run well. If I had to bench race and make a dyno prediction, I would guess you will make 420-440rwhp on an LS2 with CAI, headers and that cam. What lobes is the cam on?
Old Jan 15, 2012 | 10:33 AM
simplegto's Avatar
simplegto
St. Jude Donor '11-'12-'13-'14
I have 72,000 on a Lunati cam in my LS2 GTO but it only has .567 lift. A few people with high lift cams have had the lifter turn in the trey and wipe out the lobe. Link bar lifters are a good idea with high lift cams.
Old Jan 15, 2012 | 04:59 PM
Brian@RPT's Avatar
0Brian@RPT
Former Vendor
With great quality parts, proper installation and tuning.....you will have no issues from a cam swap and many miles of enjoyment. Will you be performing the installation? If so, there are many things to consider like the use of loctite in key areas, knowledge of proper torque specs, use of assembly lube and making sure all sealing surfaces are clean. Also, ensuring you have the proper cam for your goal is very important.
To Cammed Corvette reliable?
