08 A6 won't upshift from 1st
Old Jan 19, 2012 | 01:06 AM
Badburn's Avatar
Badburn
5th Gear
Default 08 A6 won't upshift from 1st
Driving in S mode and using the paddle shifters, this car wont shift out of 1st gear under power. Part throttle or lower rpms seems to work fine, but wot and hitting the paddleshifter at around 6200- it wont shift. It falls on it's face on the rev limiter. As you can imagine, I'm not a big fan of driving it into the ground on the rev limiter until I realize that the shift isn't going to happen. Is this normal? Could it be a product of the torque management?
Old Jan 19, 2012 | 01:47 AM
MisterMidlifeCrisis's Avatar
MisterMidlifeCrisis
Are the tires spinning? If you go at a steady speed at 6000 RPMs and paddle it to upshift, will it shift?
Old Jan 19, 2012 | 07:34 AM
filmjay's Avatar
filmjay
St. Jude Donor '10
What does it do in D?
I've only had two A6 issues thus far.
One was due to a faulty F1 paddle from WCC...which they swapped out. It wouldn't shift, just as you described.
Two, was in D, which scans say is a sticking solenoid. In wich case, I drive it with the paddles til its warmed up.
..just my .02
Old Jan 19, 2012 | 07:35 AM
chaver450's Avatar
chaver450
Turn off the traction control and it will shift. I have encountered this without using the paddles as well, it just won't shift if it is spinning or thinks it will spin. I was wearing the rev limiter out when I first got my car.
Old Jan 19, 2012 | 08:09 AM
RoadRebel's Avatar
RoadRebel
Assuming its stock 6200 is way to late to hit the paddle shift, especially first gear. Hell, I dont at 6200 at wot it will shift into any gear without hitting the rev limiter (6400)
Old Jan 19, 2012 | 09:06 AM
Badburn's Avatar
Badburn
5th Gear
I don't think the tires are spinning, I usually do it with the traction control on, and roll the throttle down gently, then shift. I guess the traction control could be actively stopping the tire spin. I'll try tinkering with it a bit more.
..just my .02
The paddles seem to work fine in every other gear, and it works ok in D, I just don't like the mushy feel of the shifts in D. I also believe it starts out in 2nd gear in D, I'm still learning about this car, I've had it for about a month.
I'll definately try that, but I predict smoking tires.... lol
Yes, all stock. I think the redline on the tach is about 6500, so giving it 300 rpm notice to shift seems reasonable to me, lol. Like I said, the car is still pretty new to me. I did try shifting it a little sooner lastnight, and it did the same fall on its face no shift thing.
Thanks for the ideas guys, the rain is here, so it may be a couple days till I get to drive it again
Old Jan 19, 2012 | 01:03 PM
RoadRebel's Avatar
RoadRebel
You need to pull the paddle waaay sooner
Old Jan 19, 2012 | 06:01 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Push, not pull!
But yes, there is lag both in the tach and in the upshift. Start out by hitting the paddle at 5500 rpm, see if that helps.
Work your way up 100 rpm at a time (not all in one morning, overheated tranny) until you find a number that will get you shifted before shafted (rev limiter).
For drag racing, most people put it in Sport but let the computer do the shifting. Testing on the street, mine seems to shift right about redline when done that way.
Old Jan 19, 2012 | 06:11 PM
MisterMidlifeCrisis
Yup. With as fast as the revs build in first, I hit the paddle when the needle screams past about the 5800 RPM mark.
Old Jan 19, 2012 | 11:16 PM
DSOMC6's Avatar
DSOMC6
That is my work-around as well and apparently many others. Not happy about it but just learned to just drive the car that way. Now that the subject has been brought-up, it would be nice to know if there's a simple programable solution (via HP Tuners)? You really shouldn't have to cringe, cross your fingers and say a Hail Mary when going wot in first gear.
edit: you can always install a shift light.
Old Jan 20, 2012 | 01:10 AM
res0n0xg's Avatar
res0n0xg
As everyone else said, you're just hitting it way too late. I have the same problem all the time...
it's really tough to gauge 1st gear in the auto under WOT using the paddles
Old Jan 20, 2012 | 05:06 AM
MisterMidlifeCrisis
You can do two things via a tune. The most significant one would be to change the operating parameters to make the shift happen faster. The second would be to raise the redline, not so that you use all of the additional RPMs as power falls off pretty rapidly at the top end, but to give yourself a little extra buffer in case you're late with the shift.
Old Jan 20, 2012 | 09:39 AM
Badburn's Avatar
Badburn
5th Gear
So am I understanding correctly that the car cancels the shift altogether if you are too close to the redline? or if the traction control is active?
I'm positive that I have hit the paddle before in the 5500-6000 range and still got a no shift. And I'm also positive that I have got a no shift with the traction control off.
Not trying to be argumentative here, I'm trying to understand exactly what condition causes this.
Old Jan 20, 2012 | 11:41 AM
MisterMidlifeCrisis
It will not cancel a shift if you are too close to the redline. You may hit the redline before the shift occurs, though. That's why if you are accelerating at full throttle, you have to hit the paddle several hundred RPMs before redline.
If the wheels are spinning, as they can do at the top of first gear when the engine is at its power peak, the transmission will not shift. I don't know if turning off traction control makes a difference - I would think that it wouldn't make a difference.
When does this situation happen for you? If you're trying to run a quarter mile, it's probably best to leave it in "S" mode and let the transmission shift for you. If you're on a road course, it's probably better to accelerate in second gear as you'll be able to get more smoothly on the throttle more deeply and a bit sooner rather than having to feather the throttle in first gear.
Old Jan 20, 2012 | 12:26 PM
oldnotslow's Avatar
oldnotslow
When using paddle shift my a6 will shift fine at part throttle but will not shift out of 1st wot if the traction control is on. Tires are spinning so traction control must try to control the shift if it's on.
Old Jan 20, 2012 | 01:40 PM
6Speeder's Avatar
6Speeder
Are you running stock sized tires? The transmission shifts based on rpm and speed, if they don't match this can occur.
Old Jan 20, 2012 | 04:05 PM
mikeCsix's Avatar
mikeCsix
This "problem" is normal operation for the 2008 A-6 transmission. You have to lift the throttle before tapping the paddle otherwise you hit the rev limiter. Mine did the very same thing at Pacific Raceways last year on the road race track. My instructor, who has tons of time and raced these cars (read way more experience than I), said the very same thing. He is a big fan of the A6 too. You might be able to get around this behavior by getting a transmission tune where you can also get around the problem of not automatically downshifting into 1st gear when using the paddle shifters in 'S' mode, but you should consult with the experts on that, either Tommy Wong down in Vancouver, Wa. or Chuck Cow or ECS, all of which I have heard nothing but good things about so you can't go wrong.
To 08 A6 won't upshift from 1st
Old Jan 20, 2012 | 04:12 PM
mikeCsix's Avatar
mikeCsix
As MisterMidlifeCrisis says, if on a road course, don't bother to seek the red line in first gear, save it for second gear. At PR, the slowest part of the track is best negotiated in second gear anyway - but I have run into the same problem with WOT and trying to upshift in other gears than first. I came out of turn 9 heading into the front straight, I was in either second or third at the time and forgot to lift before tapping for the next gear.
Old Jan 20, 2012 | 06:46 PM
Chuck CoW's Avatar
0Chuck CoW
Former Vendor
St. Jude Donor '07-'08-'09-'10-'12-'13-'14
Default Give me a call....
Hey man.. Give me a call so I can talk with you about the problem you're having....
I think I can help you.
914-332-0049
Chuck CoW
Old Jan 20, 2012 | 08:38 PM
Gearhead Jim
St. Jude Donor '13
Geez, all I do with mine is to plan ahead a little. Because the engine is winding up so fast in 1st, and there is some lag in the upshift, and probably also some lag in the tach (more rpm than you see), you need to hit the paddle well below the redline. If I hit my paddle at about 6,000 under full throttle in 1st, the tach just gets to 6,500 by the time the shift happens. In 2nd, I can wait until about 6,300.
No need to lift the throttle unless the rear wheels are spinning, and I think that using comp mode on the AH will allow you to upshift even while experiencing wheelspin.
There is some variation from car to car, and more variation from year to year; so individual experimentation is nesessary.
