Lg adjustments?????
Old Jan 22, 2012 | 10:40 AM
grumpstar's Avatar
grumpstar
Default Lg adjustments?????
I'm being told by LG Motorsports to set the front at a higher setting than the rear ...ie....5 front. 4 rear. That is where it is..it seems to ride a little hard, but not handle as nice as I want. I may be double talking, but..if I raised the car 1" by adjusting the springs,(which is the way they same to raise and lower) do you think that would stiffen it up, and then go and back down the settings to 4 front. 3 rear? Or 4 and 4? Bring it on guys...I need your opinions.
Old Jan 22, 2012 | 10:59 AM
C7&7's Avatar
C7&7
I am assuming you're referring to coilovers?
I am not real sure I am following your question? Are we talking about ride height or ride stiffness? I have my stiffness set to 9 at all 4 corners and love them.
Old Jan 22, 2012 | 11:16 AM
grumpstar's Avatar
grumpstar
Hi Tim..we spoke when I was installing and I tried that...it really hit hard on the bumps,manhole covers, potholes, etc for everyday driving. on good smooth roads it felt great. Today I am going to pull up the carpet and sound proof the rear and raise it back up that 1" it dropped when I did the coil overs. That also may help with the road noise.
To Lg adjustments?????
