Clutch Release (Throw Out) Bearing Source
Old Jan 25, 2012 | 11:21 AM
5 Liter Eater's Avatar
5 Liter Eater
St. Jude Donor '11
Default Clutch Release (Throw Out) Bearing Source
I'm looking for just the bearing, not the whole slave. GM doesn't seem to sell it separately.
Old Jan 25, 2012 | 12:46 PM
camarochevy19702's Avatar
camarochevy19702
Ditto, I have a low mileage one as well. I can snap a picture of it tonight if you want to see it. Don't think it will cost much to ship, so if you cover shipping I can send it to you
Old Apr 4, 2012 | 08:43 PM
5 Liter Eater
St. Jude Donor '11
TTT. Can't believe these things are not available.
Old Apr 4, 2012 | 09:21 PM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Why do you need it separate Bill? I think most replace as a unit with the slave. Did yours go bad?
Old Apr 5, 2012 | 09:48 AM
5 Liter Eater
St. Jude Donor '11
Since before I took it down to do the motor swap and turbo kit, when the car got warmed up, if I started it hot it would make a marbles in a can type sound from the bellhousing area. About 10-30 seconds after startup it would go away. Pressing in the clutch didnt make any difference in the sound. My throw out seems fine and since I couldnt find one while the motor was out I used it. It made the sound again yesterday now that I can drive it enough to get warmed up so I just wanted to replace it while I'm in there putting a new clutch in. Could be the front TT bearing too but *** it. I am sick of working on this thing. I'll put up with the sound until something breaks.
Old Apr 5, 2012 | 09:58 AM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Bill I have limited experience here as I've only done a couple of clutches and they were on C5's (split bell housing made those much easier). That said, it sounds like a bent or screwed up pilot bearing to me, not the throw out bearing, since pressing the clutch doesn't make a difference in sound.
It happens that when you are stabbing in the torque tube/trans/diff you can **** or otherwise molest the pilot bearing causing it to make noise and ultimately fail.
In particular I can see this happening because you're man handling that thing on your back in a garage...
You can check the torque tube bearing for play and sound when you have it all apart and if it's screwed up, get one then.
Old Apr 5, 2012 | 10:29 AM
5 Liter Eater
St. Jude Donor '11
Yea my pilot in my old motor seemed fine and I put a brand new one in the new motor so I don't think it's the pilot. The input shaft looked good too. I check for play in the TT and it "seemed" fine. It's likely the TT bearing since pressing the clutch in doesn't change the sound at all. The only way to tell is to take it apart and I'm under the gun to get the car together for an airstrip HPDE so it'll have to wait.
Old Apr 5, 2012 | 10:35 AM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
I'd put in a new pilot bearing if I was you. Easy to do with the right tool and cheap. The fact that the clutch doesn't change it leads me away from the throw out, and even the torque tube, as both of those should change any sound they are making when the clutch is disengaged.
And the pilot is easy to screw up wrestling a drivetrain on a garage floor, particularly if you drew the torque tube in with the bolts (not that you'd do that....)
Old Apr 5, 2012 | 12:09 PM
JUIC3D's Avatar
JUIC3D
St. Jude Donor '11-'12-'13-'14
Bill, I don't know if it'll help, but I'll be replacing my 30k mile OEM clutch in a few weeks and I'm also replacing the slave cylinder with a new one from GM. I haven't had any release/chatter/strange noise issues or anything, so I assume the bearing is fine. I just want to replace the whole unit while the drivetrain is out.
If you want, I'll be glad to ship the old throwout bearing to you.
Send me an address and I'll get in in the mail as soon as it comes out. I'm doing the clutch swap the weekend of April 21.
Old Apr 5, 2012 | 02:16 PM
5 Liter Eater
St. Jude Donor '11
Thanks but I'm doing my clutch this weekend. Noise or no.
Old Apr 7, 2012 | 12:12 AM
5 Liter Eater
St. Jude Donor '11
Here's the sound. Stuck my phone under the car when it made it tonight. Don't know that the sound came through very well. Kinda of just sounds like engine noise but it's not. About 5 seconds after I start moving, the sound goes away.
Old Apr 7, 2012 | 11:46 PM
5 Liter Eater
St. Jude Donor '11
So long story but I found out that the noise was the starter not disengaging. Tonight while installing my clutch the starter got grounded out for a few seconds. When I got it all back together and tried to start it the starter kept cranking. Only way to stop it was to pull the battery. It made that same nails in a can sound and when the battery was pulled it made the same spin down noise. So I have to figure out if I fried the starter or something else but at least I found my mystery drivetrain noise.
Old Apr 8, 2012 | 12:09 AM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Had the exact issue with replacement starter for my F-150. Brought it back and got a replacement and all is great.
Old Apr 8, 2012 | 07:47 AM
taken19's Avatar
taken19
Track Junky
Give Mike Yeager at East Coast Performance a call. When I did my torque tube rebuild, he had a couple laying around and sold me one for about $35. I'm almost positive it was him, but it was about 18 months ago.
To Clutch Release (Throw Out) Bearing Source
