Lower or not to lower???
Old Jan 29, 2012 | 04:39 PM
  #41
Cyber Greg's Avatar
Cyber Greg
Originally Posted by USAF-Vette
That's exactly what he was saying. Lowering with the stock bolts is ok because they will lower your car a small amount. People often go too far with aftermarket bolts by slamming their cars and taking away most of the suspension travel. Everything in excess is bad.
Okay, cool, thank you.
Greg
Old Jan 29, 2012 | 10:20 PM
  #42
MIGHTYM0USE's Avatar
MIGHTYM0USE
i dunno about lg/pfadt or the other nice coil overs, but my stance coilovers have an adjustable lower so that your available shock travel can be maximized.
as my car sits i have over an inch of 'shaft exposure' front adjustment is maxed out rear can go more. this corresponds roughly to the amount the car can go down before touching the ground
Old Jan 30, 2012 | 03:50 AM
  #43
glass slipper's Avatar
glass slipper
Originally Posted by Pfadt Racing
Well the geometry of the suspension stays the same... your control arm lengths don't change. What lowering does do is put the car at it's static ride height in a different place in the suspension travel.
Of course the lengths of the control arms don't change, that wasn't what he was referring to. The angles of the control arms do change and that is part of the geometry of the suspension. GM recommends a maximum amount for the car to be lowered based on the toe and camber curves. When you lower the car too much, you fall out of the optimum toe/camber curves for best handling.
The bottom line is to slam car for best looks but stay within the factory limits of the spring bolts for best handling.
PS I'm absolutely baffled why a person of your caliber would say "the geometry of the suspension stays the same".
Old Jan 30, 2012 | 01:10 PM
  #44
Pfadt Racing's Avatar
Pfadt Racing
I think we are actually on the same page here. Angles will absolutely change, but as you lower the vehicle you won't see behavior that wasn't modeled into the suspension from GM. There is a pretty generous negative camber gain as you move into bump travel... so as you lower the car you will see proportionally more negative camber for every inch of bump than you would have at the stock ride height, but for a performance vehicle that's not necessarily a bad thing.... especially with most street alignments on these cars starting in the sub 1 degree range.
As far as our recommended ride heights go we are again on the same page. Even with our coilover products we don't recommend slamming the car for best performance, unless it's a track vehicle running an optimized Aero package. We know that a lot of our customers are running really low ride heights because of the look, and our coilovers will allow them to run the aggressive ride heights their looking for without running into travel and ride quality issues with the leaf springs.
The biggest point we were trying to make is that extra negative camber gain aside, once you address the leaf springs there isn't a major change in the functionality of the corvette suspension as you lower it. Arm lengths aren't changing and positions of the pickup points aren't moving. It works pretty well at a variety of ride heights. What absolutely does change as you lower the vehicle on leaf springs is the amount of travel that's available, that's a bigger issue that's best dealt with proper hardware like coilovers for best performance.
Originally Posted by Gregory123
Could you please clarify this a bit more for me? Are you saying that the stock suspension won't be significantly compromised if you stay within the parameters of the factory lowering bolts i.e. you can lower it a bit more than how it was delivered from the factory. But, when you try to lower it further than the factory bolt will allow by using an aftermarket lowering bolt compromise occurs. Is that what you're saying?
Thank you,
Greg
Exactly. When you're lowering on factory leaf springs it's really a case of a little can be good, a lot can be bad. We definitely do not recommend lowering bolts without understanding the repercussions involved, and encourage users to not max out their factory adjustment. A subtle change in ride height, say in the 1/2" range, can make the car look more aggressive without an impact to ride quality or performance.
Old Mar 26, 2012 | 02:24 PM
  #45
apacheav8tr's Avatar
apacheav8tr
The Z looks bad *** man. How did you lower you lower it, did you use the stock bolts? I was considering going with the LG Motorsports Drop Spindles, any opinions on those? Totally off subject but what percent tint do you have on your car. I can't decide between 5% or 15%. Thanks
Originally Posted by OneBadZ06
Yes. Slam it. Sure you will get plenty of "dont do it" from the grannies here, but the car looks better, handles better, and if you know how to drive, its not an issue.
Have had mine slammed since 2008 without incident! Just take driveways/bumps at an angle and you will be fine.
Or..you can just enjoy the OEM 4x4 look.
