Raising the engine requires the removal of 2 nuts.
Dropping the cradle requires the removal (8) A-Arm Bolts, (4) shock Bolts, (2) ABS nuts, (2) power steering cooler bolts and (4) cradle bolts. All easily done with air tools.
Easy once you acutally do it and much cleaner in the end.
How long does it typically take this way VS. pulling the rack instead? How high do you have to lift the engine with this method?
If one is to raise the engine 2 inches, IM better not be in placed; also, better be closely watching for the clearance between top of bell housing and lower fire wall when the engine is being raised.
With Fast IM in placed, clearance is less than 3/8" at the top on my C6.
Clearance between top of bell housing and back of lower fire wall can easily verify from driver side, using flash light, there is a direct shot when looking past brake master and below valve cover, looks to be less than 1 1/2" on my car as is.
It is in the instruction when installing A & A supercharger, it does simplify things and save time when done right!
My intention of posting this, is not to discourage dropping cradle and raise the engine, rather, not to misled; to avoid damaging surrounding body and parts, the process is a little bit more involved. Thats what I did! YMMV!
Easy once you actually do it and much cleaner in the end.
Pretty sure the 2 ABS nuts referenced are for the vertical bracket that attaches to the front subframe and the ABS box where all the lines go to. If you look under the car on the drivers-side, it will be obvious.
