Changing Balancer..Dropping the rack
Old Jan 28, 2012 | 04:31 PM
Nova10sec's Avatar
Nova10sec
Default Changing Balancer..Dropping the rack
I have just assembled the parts and tools I think I need to swap to an underdrive pulley. Before I tackle the job, I was wondering if I would have to disconnect both lines and both tie-rod ends and remove the rack completely or just remove the one side bolt, loosen the other and just move it up a bit.
Old Jan 28, 2012 | 04:34 PM
marine&hisvette's Avatar
marine&hisvette
Your going to have to remove both lines and the rack completely. You will not have to take it all the way out. Just enough to work around it.
Old Jan 28, 2012 | 06:01 PM
Nova10sec's Avatar
Nova10sec
Thanks. From what I see its 2 lines, 2 mounting bolts, and the 2 tie-rod ends, does that sould like the extent of it?
Old Jan 28, 2012 | 06:06 PM
marine&hisvette
yes and be prepared to be spilling a lot of power steering fluid. As for the steering rack that is it. 2 tie ends, 2 mounting and 2 lines.
Old Jan 28, 2012 | 06:37 PM
JoesC5's Avatar
JoesC5
While you're down there, you might want to consider pinning your crank in case later on you decide to go with a S/C.
Old Jan 28, 2012 | 06:43 PM
CYA-Vett's Avatar
CYA-Vett
Put a two piece timing cover on too, in case of cam...Do they still even make those?
Old Jan 28, 2012 | 08:17 PM
Supersonic Gary's Avatar
Supersonic Gary
http://http://www.quicktimeperforman...over/index.php
Old Jan 28, 2012 | 09:05 PM
DSOMC6's Avatar
DSOMC6
And don't forget the 11mm (IIRC) screw that holds the steering wheel shaft to the steering box.
Old Jan 28, 2012 | 09:59 PM
marine&hisvette
It's 13mm but yea.... that's common sense though
Old Jan 29, 2012 | 03:15 AM
carlrx7's Avatar
carlrx7
St. Jude Donor '08-'09
yep, 11mm
Old Jan 29, 2012 | 06:21 AM
Brian@RPT's Avatar
0Brian@RPT
Former Vendor
Dropping the cradle and rasing the engine is easier.
Old Jan 29, 2012 | 08:47 AM
ssmith512's Avatar
ssmith512
I was wondering about this. Can you loosen the 4 nuts holding the cradle, not remove them all the way, but just unscrew them most of the way, let the cradle hang on them; remove the lower motor mount bolts, and the then jack the motor up a tad bit to gain enough room?
Old Jan 29, 2012 | 09:54 AM
marine&hisvette
Drop cradle and raising then engine... sounds a bit more harder to work with. But will work.
Old Jan 29, 2012 | 12:01 PM
07MontRedcp's Avatar
07MontRedcp
Originally Posted by Supersonic Gary
Fixed the link: http://www.quicktimeperformance.com/Cover/index.php
BJK
Old Jan 29, 2012 | 12:09 PM
timd38's Avatar
timd38
I bought an Edelbrock one, but it didn't fit. It hit the crank gear.
Old Jan 29, 2012 | 12:27 PM
ls3gotcha's Avatar
ls3gotcha
removing the rack is not hard at all. slide it half way out of the passenger side wheel well.
Old Jan 29, 2012 | 01:21 PM
BT03mach-1's Avatar
BT03mach-1
if your ever plan on doing cam i would wait. getting to that pulley and removing it is most of the work. after that the cam install its cake!
To Changing Balancer..Dropping the rack
Old Jan 29, 2012 | 03:49 PM
Brian@RPT's Avatar
0Brian@RPT
Former Vendor
Raising the engine requires the removal of 2 nuts.
Dropping the cradle requires the removal (8) A-Arm Bolts, (4) shock Bolts, (2) ABS nuts, (2) power steering cooler bolts and (4) cradle bolts. All easily done with air tools.
Easy once you acutally do it and much cleaner in the end.
Old Jan 29, 2012 | 09:20 PM
gotjuice?'s Avatar
gotjuice?
St. Jude Donor '13
Old Jan 29, 2012 | 10:53 PM
victorf's Avatar
victorf
When raise engine, need to check clearance between IM and firewall, especially if you have Fast102.
