Camber Question
Old Jan 31, 2012 | 08:53 AM
mike72's Avatar
mike72
Default Camber Question
I am going to have to buy new front tires for the second time in 50,000 miles. I know this is because of the camber setting being so aggressive. They are wearing out on the inside edge. The rears show hardly any wear. If I change my camber to only a negative .20 from the .47 neg factory setting how much will this change the toe and which way will it change? Toe in or toe out?
Thanks,
Mike
Old Jan 31, 2012 | 10:05 AM
JoesC5's Avatar
JoesC5
Thanks,
Mike
A .47 neg is not that aggressive, even for a FE1 suspension. I run .9 neg on my Z06 with wider tires then you have and that is slightly less agressive then the factory FE4 specs. You need to check the toe and set it at 0.0.
Old Jan 31, 2012 | 11:06 AM
TMyers's Avatar
TMyers
I am running 1.5 and the tires are wearing fine. Toe at 0.0 is the key
Old Jan 31, 2012 | 11:17 AM
BEZ06's Avatar
BEZ06
I am going to have to buy new front tires for the second time in 50,000 miles.....
I guess that's more than 16,000 on each set of tires - that's great life out of tires on a Vette!!!!
I think I'd recommend to leave the alignment where it is and be happy with such great wear life out of your tires!!
If anything, I'd be looking at a slight toe adjustment.
Bob
Old Jan 31, 2012 | 11:33 AM
mike72's Avatar
mike72
thanks, for the replies. I will check the toe to see what it is running.
Old Jan 31, 2012 | 12:53 PM
RicK T's Avatar
RicK T
I know you didn't ask for this but I just wanted to point it out in case you're interested. Many here have gone to the Pfadt Street Alignment and report great results with both handling and tire wear. Notice the Toe setting is 0.0 as already recommended and the Camber is higher than you're running now. The key is finding an alignment technician who will work to get the specs exact rather than just shoot for the factory "range".
http://www.pfadtracing.com/docs/camb...t-settings.pdf
Old Jan 31, 2012 | 03:19 PM
mike72's Avatar
mike72
thanks rickt, that is very helpful and gives me something to go by.
Old Feb 1, 2012 | 09:26 PM
TLTONEY's Avatar
TLTONEY
I just set up my alignment with the PFADT specs.
Front min max
Camber (deg) -0.7 -0.9
Caster (deg) 7.5 8.5
Total Toe -1/16" (0.17°) 0 (0°)
Rear
Camber (deg) -0.4 -0.6
Notes
These settings will provide good performance and good tire wear
http://www.pfadtracing.com/blog/wp-c...-9.12.2011.pdf
To Camber Question
