Spark Plugs
Old Feb 7, 2012 | 11:55 AM
C7/Z06 Man's Avatar
C7/Z06 Man
Originally Posted by dardenken
Are the AC Delcos Iridiums ? The center electrode looks the same as the Densos (Very thin).
Yes
Old Feb 7, 2012 | 12:07 PM
Shifter6's Avatar
Shifter6
Almost always the coldest plug you can run without fouling or misfiring will give you the most power. This is especially true with higher combustion pressures.
Even NA and stock moving 1-2 steps colder should allow you to run more aggressive timing. Most setups will benifit slightly from a little more timing. However if you move to a colder plug, this will increase your service interval. Also I am talking about a finite amount of power here.
There is nothing better for perfromance than a fresh set of copper plugs, period.
