Need help replacing C6 radiator
Old Feb 4, 2012 | 10:13 PM
geewez's Avatar
geewez
Default Need help replacing C6 radiator
I'm in the process of replacing my radiator with a new DeWitts radiator. I have everything disconnected and the stock radiator is ready to come out except for one thing. The AC condenser is still attached to the front of the radiator. Everything is loose but I can't seem to be able to separate the condenser from the radiator. The service manual says to open the AC lines and unbolt the hoses but I know it's not necessary to do that. I've done a search but can't find a posting from someone who's done it. The driver's side of the condenser is free but I'm fighting the passenger side. Can't lift it up high enough to clear the mounting tab. Any tips or hints from someone who has done it?
Old Feb 4, 2012 | 10:27 PM
RicK T's Avatar
RicK T
This might help:
http://forums.corvetteforum.com/c6-t...r-removal.html
Old Feb 4, 2012 | 11:02 PM
geewez's Avatar
geewez
The previous post makes it sound easy but the condenser does not "just lift up and off" and that's where I'm stuck at right now.
Old Feb 5, 2012 | 09:29 AM
irapilot's Avatar
irapilot
I am doing exactly the same thing, and was going through the same struggle last night. I was able to lift the radiator up and out of the bottom supports and shift it slightly over toward the drivers side. It was easy to free the drivers side for the AC condensor, it took some effort but I was able to free the passenger side, at which point I was able to lift the radiator out.
I am about to head out and see if I can mange to get the Dewitts in place.
Good Luck
Old Feb 5, 2012 | 11:42 AM
taken19's Avatar
taken19
Track Junky
I had to use a Drexel and trim the tabs that hold the AC condenser to the radiator to about half their size. Now it still holds in place and can be removed easily by hand.
Old Feb 5, 2012 | 11:45 AM
torquetube's Avatar
torquetube
I had the same problem.
If your old radiator is leaking, just break the plastic tab that's in the way. You're not going to re-use it.
Old Feb 5, 2012 | 11:54 AM
torquetube's Avatar
torquetube
Some folks report that they can wiggle it out, but on my car it was flat-out impossible.
I'm thinking that the difference may be Z51. Perhaps the external dimensions of the stock Z51 radiator's right tank are just slightly too big to clear.
It didn't have to be this way. If GM had made the A/C line slightly longer or the end tank a slightly different shape, it would clear without having to depressurize the A/C system. But at the factory they filled the A/C after they installed the radiator, so they don't care. These are the kinds of details I hope they fix on the C7.
HOXXOH's Avatar
HOXXOH
There must have been two suppliers of condensers, because I hear some people say how easy it is and others with major headaches.
I broke off the lower radiator tab just to get it out. It doesn't seem to have made any difference in how well the condenser stays put. If I had to do it over, I'd probably just saw/grind off part of the tab, so some of it remained.
Old Feb 5, 2012 | 12:17 PM
DSOMC6's Avatar
DSOMC6
I loosen the fitting that holds/mounts the a/c line to give it some wiggle room. Then lift both the rad and a/c condenser together a couple inches. Then, while holding the a/c condensor up with one hand I push down on the radiator and seperate the two.
If it makes you feel any better, I have dual intercooler in front of my radiator/conenser which gives me almost no room to separate them and make it even more difficult.
Old Feb 5, 2012 | 09:43 PM
geewez's Avatar
geewez
Took me awhile but I finally got the condenser off and the new radiator in. The reason the condenser didn't want to separate from the radiator is because the factory radiator with Z51 has a cutout on the lower right portion. I ended up snapping off the mounting ears on the stock radiator's right side to release the condenser. Still took awhile to reinstall the new radiator, fan and hoses and to button everything back up.
Old Jul 26, 2014 | 06:52 AM
Ahmer's Avatar
Ahmer
So snap it off? (the stupid tab on the passenger lower side?
Old Jul 26, 2014 | 08:14 AM
kedar's Avatar
kedar
St. Jude Donor '12
Agree with everyone who suggests to break off the tab on passenger side lower portion of radiator. I used a pair of channel locks, grabbed the tab and broke it off.
Old Jul 26, 2014 | 02:07 PM
victorf's Avatar
victorf
I used woodworker's flexible trim saw, without distorting surrounding plastic and left some material for reuse:
Old Jul 27, 2014 | 05:11 PM
90zcrex's Avatar
90zcrex
Did this yesterday for cam install in a z06, it is a pain in the *** but if you have another person lift up on the condensor and then take a small flatblade screwdriver In there you can pry the tab over enough to get the condensor off without breaking anything.
Old Jul 28, 2014 | 02:13 PM
victorf's Avatar
victorf
Using prying force is never a good thing. Especially with inducing stress on radiator with plastic side tanks, where it is already prone to cracking, when you least expected - unless, you don't plan to reuse or resale.
Force can have an direct effect on any object, it might cause problem which will need damage control in the future, where it could have been averted if good shop practice was followed in the first place.
Having that tab intact, physically will keep the condenser captive, won't be able to lift it up - that is the problem in the first place - if another person able to lift it, we wouldn't be having the problem to begin with interference/separation issue.
Method in removing that tab differs. I choose the least destructive to the surrounds by sawing like hot knife on butter with flex trim saw. Without inducing stress.
But then, it is just my opinion on fineness verse brute force.
Old Jun 29, 2020 | 11:45 AM
sonner's Avatar
sonner
Cruising
Default C6 z51 radiator
Hello All,
The radiator won't come out. I was going to the cut the lower passenger-site tab on the condenser side. Then I decided to do an internet search. I saw this thread. Good info guys. Thanks. I am confident that cutting the tab is the only way out.
Sonner
2007 C6, manual (MZ6 transmission) with z51 package. Radiator has transmission oil and motor oil lines connected to it. There are no additional oil to air cooling elements in front of ac condenser.
To Need help replacing C6 radiator
