Milling 243 heads
Old Feb 6, 2012 | 09:44 PM
All_Motor_C5LS6's Avatar
All_Motor_C5LS6
Default Milling 243 heads
Would i absolutely need a retune if i milled my 243 heads .012 (64cc to 62cc)? How would the small bump in compression affect my current tune?
Old Feb 6, 2012 | 10:29 PM
carlrx7's Avatar
carlrx7
St. Jude Donor '08-'09
it wouldn't hurt, i wouldn't say it would require a tune, but it should be logged for knock and correct afr.
you should just go with a thinner gasket instead
Old Feb 6, 2012 | 11:43 PM
taken19's Avatar
taken19
Track Junky
Why go through all that effort and not want a tune? You are most likely fine depending on your installed cam but it wouldn't hurt to check the tune/scan.
Old Feb 7, 2012 | 06:28 PM
Justasheet's Avatar
Justasheet
Old Feb 7, 2012 | 06:47 PM
C7&7's Avatar
C7&7
Really? Why pull the heads and not get them worked? Ported, milled,etc. That is a lot of work to just put on a thinner gasket and bolt the head right back on. Just my $.02
Oh, and I would defiantly re-tune the car if I added compression.
Old Feb 7, 2012 | 07:00 PM
Justasheet's Avatar
Justasheet
Agreed but he never mentioned porting them.
Jeff
Old Feb 7, 2012 | 07:28 PM
ls3gotcha's Avatar
ls3gotcha
Get a valve job while there off too
Old Feb 7, 2012 | 09:02 PM
LEAVINU's Avatar
LEAVINU
Did you call Rob yet?
Old Feb 8, 2012 | 09:06 AM
All_Motor_C5LS6
Yes, I spoke with him yesterday.
To Milling 243 heads
