rear axle seal
Old Feb 7, 2012 | 12:22 PM
gizsmo0's Avatar
gizsmo0
Default rear axle seal
has anyboby reaplaced the rear seal on just one side?did you have to drop the whole axle.thanks
Old Feb 7, 2012 | 06:46 PM
gizsmo0's Avatar
gizsmo0
Old Feb 8, 2012 | 11:41 AM
Kenny94945's Avatar
Kenny94945
No, if you mean the whole axle as the entire differential.
Yes, you have to remove the axle to replace the seal.
Basically, get the hub out of the way to remove the drive axle.
Old Feb 8, 2012 | 12:09 PM
gizsmo0's Avatar
gizsmo0
Sorry yes that's what I meant ,do you have to drop the differential to replace the seal in one side
Old Feb 8, 2012 | 02:29 PM
Austin-vette's Avatar
Austin-vette
St. Jude Donor '08
There is no need to lower the differential to replace either or both axle seals.
Old Feb 8, 2012 | 03:13 PM
gizsmo0's Avatar
gizsmo0
Thanks,
Old Feb 16, 2012 | 10:34 PM
gizsmo0's Avatar
gizsmo0
I just found out there is know need to remove the cover either wish I would have known that three hours ago
To rear axle seal
