Exhaust Installation Question
Old Feb 7, 2012 | 02:52 PM
dr_vette's Avatar
dr_vette
Cruising
Default Exhaust Installation Question
I'm looking to take off factory exhaust and put on a new one (Borla, Flowmaster...haven't decided).
My question is...I need an installer and have been told to make sure I get one who has the computers to re-calibrate the car (2005 C6 coupe).
Does anyone know if this is true? I'm only replacing from the Cats back. So do I have to have some special Vette guru exhaust expert...or will any Muffler shoppe be able to do this?
Suggestions please? and thanks in advance....
Old Feb 7, 2012 | 02:57 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Cat backs should not need any tuning after installation.
Elmer
Old Feb 7, 2012 | 02:59 PM
FloydSummerOf68's Avatar
FloydSummerOf68
Any muffler shop can drop the stock exhaust and replace it with whatever you buy in no time at all.
No tune needs to be done.
Shouldn't pay more than $125
Old Feb 7, 2012 | 03:09 PM
cdkcorvette7's Avatar
cdkcorvette7
Where are you located? You should fill out your profile...
Old Feb 7, 2012 | 04:39 PM
Speedforhire's Avatar
Speedforhire
Cat-backs do not require a retune. However, I saw a thread here recently where the blogger was quoted an astronomical price and told he would have to have the rear end removed before the install. DON'T BE FOOLED! It's a simple process that you could do yourself with some good jackstands. If you're providing your own mufflers, it should not cost more than a buck & a half.............
Old Feb 7, 2012 | 05:13 PM
eboggs_jkvl
Moderator emeritus
I've switch my catbacks from B&B Bullets to B&B Rte 66 to NPP and all in my garage on jackstands and I'm 68.
Elmer
Old Feb 7, 2012 | 05:24 PM
ls3gotcha's Avatar
ls3gotcha
Buy jackstands and do it yourself
Old Feb 7, 2012 | 06:15 PM
ricknyc23's Avatar
ricknyc23
Around here, the cheapest you will find to install is 150.00
Old Feb 7, 2012 | 08:53 PM
FloydSummerOf68
That's true...it's pretty simple, but the first time you do it it'll probably take 2.5 hours on jackstands with hand-tools. Especially if the car has some miles on it and the bolts and pipes are harder to break loose. Just depends on what your time is worth.
Old Feb 7, 2012 | 11:14 PM
djbrun's Avatar
djbrun
Please post your location, if you live near me I will show you how do this. It is an easy job.
DJ
To Exhaust Installation Question
