starter
Old Feb 6, 2012 | 11:01 AM
dboelens's Avatar
dboelens
Default starter
Old Feb 6, 2012 | 12:13 PM
dboelens's Avatar
dboelens
Default starter
Old Feb 6, 2012 | 02:35 PM
TexasHiwayman's Avatar
TexasHiwayman
Is replacing the starter in a base 2006 so easy I shouldn't be asking how? Anyone have a diy thread?
Thanks.
Old Feb 6, 2012 | 04:29 PM
cdkcorvette7's Avatar
cdkcorvette7
Thanks.
Where did you first ask the question? It's a pretty simple procedure; here's how I did it.
Lower windows all the way down
Disconnect Negative Battery Terminal
Raise and safely support the front of the car.
Remove the Mid-pipe
Remove the right front cat
Disconnect the electrical connections to the starter (pay attention to the order that the electrical connections are in and label them so you can reinstall them on the new starter in the same order).
Hold on to the starter so it doesn't fall and remove the two bolts that hold it in and remove the starter.
Reverse the steps to install the new one.
Old Feb 7, 2012 | 07:16 AM
TexasHiwayman
Remove the Mid-pipe
Thanks for the reply. The reason for my comment was I couldn't find a thread for changing a starter on a C6. This will be my third. 1st one died 5 days before warranty exspired. Car has 65000 mi. Saw I can buy 4 chinese starters for the cost of an OEM chinese starter. So I'm going to buy 2.
My car has a cat-back flowmaster system. I'm assuming that it uses clamps. I'll find out later today
Going to order the part after I pull it. Any way I can check it/test it myself or do I need to go to a parts store? The solenoid is working.
Thanks for your time and info.
Old Feb 7, 2012 | 12:09 PM
cdkcorvette7
Three starters in 65K miles is ridiculous. Something is wrong... Do you have long tube headers? Are you sure it's your starter that failed and not another component?
You shouldn't have to remove the cat-back portion of your exhaust; just unbolt it from the mid pip and drop the middle section...
Old Feb 7, 2012 | 02:30 PM
TexasHiwayman
First one lasted 32000, second one 33000. Nothing other than exhaust system. Jacking the car up now. Will look for issues under the car. I'm getting the starter re-built at a place that will be able to determine root cause (Texas Alternator Service). $140 worst case.
Old Feb 7, 2012 | 09:02 PM
TexasHiwayman
Update.
Starter was fine. Solenoid was toast. Guy at Texas Alternator Service said it may be the original solenoid. $35 + tax, the guy changed the solenoids, inspected the innards and tested the assembly for free. In less than 20 minutes total
Re-installed it. Fired up instantly.
We only pulled starter, no exhaust components.
Thanks much for all info and help
Old Feb 7, 2012 | 11:28 PM
cdkcorvette7
Update.
The starter solenoid is prone to heat related failure because of it's proximity to the headers. Yours is still failing much sooner that it should; but if you want to get a little more life out of it you should wrap it in heat wrap before installing it to shield it from the heat.
To starter
