The tire pressure sensor ??
Old Feb 10, 2012 | 09:34 AM
itorfeo's Avatar
itorfeo
Default The tire pressure sensor ??
You can turn off the tire pressure sensor?? as??
I want to change the whells and does not fit the original sensor.
Old Feb 10, 2012 | 09:45 AM
el es tu's Avatar
el es tu
youd just install sensors that will fit on the new wheels and activate them.
if you cant find some tpm sensors to fit the new wheels, this is a trick that some have used with success:
you can have the current sensors removed, and put them into a sealed pipe with an air fitting, fill the pipe with enough air to reach an acceptable pressure, and keep it in the vehicle. while this has worked, there are some people that have issues with this method.
