Question on oil catch can installation
Old Feb 13, 2012 | 02:56 AM
X25's Avatar
X25
Sr.Random input generator
Default Question on oil catch can installation
I wanted to be sure and check with you guys: are these ports shown below the right ones to install catch can? Btw, now that 2009+ dry sump system has baffling, I presume we don't need to put a catch can on its return line?
Thanks!!
Old Feb 13, 2012 | 03:09 AM
MisterMidlifeCrisis's Avatar
MisterMidlifeCrisis
Yep, those are the ones. You probably pulled a "U" shaped, ribbed, hard plastic piece off them, right?
Old Feb 13, 2012 | 04:05 AM
X25's Avatar
X25
The hose's surface actually looks like a kind of conduit unlike the flat surface I saw from pictures on other threads; perhaps they changed the design in '12 models.
Old Feb 14, 2012 | 03:31 AM
MisterMidlifeCrisis
Well, I said "ribbed" but that's inaccurate because that kind of denotes that it is ribbed along the length of the hose. It's actually circumferentially ribbed like the conduit you're talking about. Mines is an 11 so probably the 11 and 12 use the same piece.
To Question on oil catch can installation
