Crank pulley bolt question
Old Feb 23, 2012 | 04:26 PM
ashanson's Avatar
ashanson
Default Crank pulley bolt question
I'm in the process of replacing my underdrive pulley with a stock one, and after taking out the bolt I found this:
Does just the lower part of the bolt that is darker actually thread into the crank, or does the upper yellowish part thread in also? There is a black chunk of something stuck pretty good to the bolt, and it's just past/outside the black part of the threads. I'm really hoping I didn't screw up the crank threads, could this be a combination of excess loctite and grease that hardened?
Anyone else ever have this issue or know what it could be? Any help is greatly appreciated!
Old Feb 23, 2012 | 10:57 PM
Redrocket1045's Avatar
Redrocket1045
It's probably the locktite junk GM applies to the treads. Just be sure to clean out the treads in the crank snout super good. You don't want any crud in there to throw your torque readings off when you tighten the crank bolt down. Use a wire wheel to clean the "old" bolt and run it down the crank snout back and forth and blow out all that crud with compressed air. Consider using a new ARP bolt. Some swear by the GM bolt while others would rather use ARP. Good Luck.
Old Feb 24, 2012 | 12:42 AM
boraxman's Avatar
boraxman
If you use a GM bolt be sure to get a new one and torque properly,,,they are TTY (torque to yield) and one time use.
The good part is, theyre cheap.
Old Feb 24, 2012 | 01:08 AM
ashanson's Avatar
ashanson
Got the crank pulley off, what a PITA. I've never taken one off before, needed to get out the breaker bar to get enough torque on the puller, maybe I'm just weak.
I took a good look at the inside of the crank, and I found a bunch of little remnants of hardened goop, but the threads seem 100% intact still, which is a relief to say the least. I cleaned them out as best I could and will be running the bolt in and out a few times to clean up the remainder of what may still be in there.
This is an aftermarket crank and internals, not OEM stuff. I believe DRM installed the pulley, I'll have to give them a call to see what they use when installing it. I'll be ordering a new bolt to go in with the new OEM pulley.
Old Feb 24, 2012 | 07:53 AM
stanger383's Avatar
stanger383
St. Jude Donor '09
2 words.......... RED LOCTITE!
Old Feb 24, 2012 | 03:57 PM
victorf's Avatar
victorf
I am very curious as to why you would choose to go OEM on the pully.
Old Feb 25, 2012 | 04:12 AM
ashanson's Avatar
ashanson
Supercharger.
Old Feb 25, 2012 | 01:16 PM
victorf's Avatar
victorf
For peace of mind, I am using one ATI Super Damper in stock sized configuration.
Old Feb 25, 2012 | 01:26 PM
ashanson's Avatar
ashanson
I thought about going aftermarket, are the OEM ones that bad? I have a guy willing to trade me his brand new stock one plus $75 cash for my used SLP.
Maybe I shouldn't be such a cheap a$$ haha, after spending a few grand on the SC kit, what's another $400 for something like an Innovators West pulley. I thought about going with the 10 rib 10% overdrive in the for sale section. I don't need 10 ribs, but it would be nice if I ever step up to an 8 rib setup, one piece already out of the way. I also have a fairly big/high overlap cam, so I'm going to lose a pound or two of boost, the 10% overdrive could help make up for that.
Old Feb 25, 2012 | 02:38 PM
victorf's Avatar
victorf
Gland you are thinking!
OEM is bad even for stock application due to the poor elastomer bonding material.
Old Feb 25, 2012 | 03:33 PM
taken19's Avatar
taken19
Track Junky
The dark part is the threads engaged in the crank, nothing else. The lighter part is the threads that were not engaged.
A new bolt is a must - do not reuse the old one except to seat the balancer back on.
Old Feb 25, 2012 | 07:36 PM
glass slipper's Avatar
glass slipper
Originally Posted by taken19
...do not reuse the old one except to seat the balancer back on.
This is a great idea right up to the point where the threads gall and you end up having to remove the engine to replace the crankshaft because you just ruined the threads. It doesn't happen often but it does happen...the previous owner of one of my 'Vettes did it but glued the bolt in so I could have the pleasure of dealing with it.
A better idea is to get a harmonic damper installer...it costs a little extra initially but it could save you $$$ and headaches down the road. I made my own installer from all-thread, too easy and it was cheap.
Old Feb 25, 2012 | 09:32 PM
victorf's Avatar
victorf
^^^^So true!
You can improvise but must be correctly done. Running thread B16 stud with thrust bearing + washer wouldn't even leave mark on the damper!
Old Feb 26, 2012 | 12:21 AM
taken19's Avatar
taken19
Track Junky
Glass, I respect your thoughts as you provide valuable information on this forum many times over. I do agree that a tool specifically made for the job is always the best option.
I thought I remember reading somewhere that using the old bolt was standard practice even with the dealership. I may be wrong though. I would say that as long as the threads appear damage free and clean you will be fine. Galling threads is very common in stainless and aluminum but not as common with carbon steel (it's been a long time since I have researched this though so I may be wrong again).
Take it for what it's worth - one data point that happened to work out for me.
Old Feb 26, 2012 | 09:06 AM
pit-man's Avatar
pit-man
I have read a couple threads thru the years where someone stripped the first few threads in the crank tyring to use the old bolt. Just go to NAPA and get a little longer bolt and start and tighten down the pulley till you get to 150lbs or so, then back it out and insert your new bolt that is the shorter one and finish torquing it down.
I have been using and loaning out my longer NAPA bolt for years now.
To Crank pulley bolt question
