Proper oil temperature before going WOT?
Or, do you have a solution for that as well? I have a vented shroud and forward-placed maf, in front of the radiator.
- I keep the engine running until it hits 100 degrees coolant to even start driving. Since my car is in the garage, the engine is never colder than 60 degrees (Fahrenheit) and it takes less than a minute to hit 100 degrees. It is usually ready by the time I chose my radio station or hooked up my phone for audio.
- Once I start driving, I drive with very low throttle input and short-shift until my oil temp gets to 100 degrees. Once it does, I feel free to drive however I want at the street.
- I only drive my car with no restraint (at the track, for instance) once the oil hits 130 degrees.
I don't wait for 150, etc. like others. I used to, with my LS2 Z51, but with Z06 and now with my GS which also has dry-sump, it would take forever for it to reach those temps, and I am not sure if it's really necessary. Sure, ideal is around 190, but the synthetic 5w-30 is already pretty fluid by the time you reach 100, and holding back on driving as you'd like until you literally reach your destination does not justify the minimal benefit in my opinion
O' Forum Experts, I beg of you to grant me pardon for my type-o above! When your crankshaft is rotating at six thousand revolutions per minute, what do you think happens if there's inadequate separation/lubrication? (hint: it's bad)
Do you really think that just because your dash says "70psi" during a cold start that oil is flowing through all of those "itty bitty splaces?" Have you ever tried to pour standard weight oil at 20 or 30 degrees temperature and noticed how differently it behaves from that of well-heated oil during an oil change?
In summary, oil pressure is not to be confused with oil flow. High oil pressure does not always correlate with high oil flow. There are plenty of resources around covering this topic, and the previously linked "BobtheOilGuy" is a pretty good one for covering concepts on viscosity relative to temperature, and why this is important.
God help me if I've misspelled a word - the rest of my post shall have been in vain. Just don't hate me because I use Rejex instead of Zaino!
lets all love each other and our awesome corvettes.
If I had an electric water pump with or without a main fan switch, then I could shut off the engine. It's obvious it'd cool quicker with the fan on.
By letting the engine run, it keeps the oil temps high (200-220) and the coolant temps below 190. I just wish I could hold the trans temps around 160-170.
I have a Mizair Electric WP and a manual fan switch... After a 1/4 mile run I pull into my pit spot, shut off the engine, & run the FAN & Electric Water Pump with the engine OFF.. if takes 10 min or less to get the temp from 190 to 140 deg. but the oil Temp remains over 160..I can make 10 runs using my Optima Yellow Top Group 34....
Best thing I've done Especially if I win a few rounds, & we have only 5 -10 min to cool down... I NEVER have to go to the starting line over 160 deg... and oil temp is always over 160...
A little conflict is good for the soul.
it'd be like a nice, tanned italian chick next to a voluptuous blonde bombshell.
also an update to my original post......as the temps have been getting warmer i have been seeing ~180 degree oil temps much more regularly. back when i first started the thread it wasn't getting above 75 degrees here in socal.
