Ported FAST 102 or non ported?
Old Mar 2, 2012 | 10:44 PM
Pahrump's Avatar
Pahrump
Seems that for only 20% more money to get the ported theres about double the power gain...
Old Mar 3, 2012 | 07:32 AM
LemansbluebyU's Avatar
LemansbluebyU
St. Jude Donor '12, '15
Pardon my ignorance but which FAST manifold would be best on the LS-7 and would the gains be the same or similar with coresponding mods?
Old Mar 3, 2012 | 09:36 AM
philly07c6's Avatar
philly07c6
so the best option for ls2 is fast 92 ported. that being said are they still available for sale, i havent been able to find any.
Old Mar 3, 2012 | 10:59 AM
debo's Avatar
debo
I don't think they are still for sale by vendors, but you may be able to find a used one. I've been looking also and haven't had any luck.
Old Mar 3, 2012 | 11:44 AM
LEAVINU's Avatar
LEAVINU
Always wondered why FAST released a 90 and 92mm for LS1/2's? Porting a 90mm would easily become a 92 if not greater. With the TB's being 90mm ish to begin with what's the big deal with the additional 2mm to start.
Just curious.
Old Mar 3, 2012 | 12:44 PM
99blancoss's Avatar
099blancoss
Former Vendor
St. Jude Donor '10-'11-'12
correct FAST discontinued them
Old Mar 3, 2012 | 01:13 PM
Dragracer_Art's Avatar
Dragracer_Art
If the unported 102 is as good as the discontinued ported 92... the solution seems pretty obvious.
Hinson sells the new 102's @ $799 shipped.
Old Mar 3, 2012 | 01:15 PM
99blancoss's Avatar
099blancoss
Former Vendor
I think Hinson has the best price on them, I've not seen them for less anywhere
Old Mar 3, 2012 | 01:18 PM
Dragracer_Art
You are correct...
http://forums.corvetteforum.com/c6-p...ls7-truck.html
Easily $25-$50+ cheaper than anywhere else.
Old Mar 3, 2012 | 01:55 PM
victorf's Avatar
victorf
Originally Posted by Dragracer_Art
You are correct...
You are right on, on that. Additionally, unlike most vendors that tagged on shipping to non continental US for additional profit, Hinson made concession, sent it to me at a price that earned my respect.
"If the unported 102 is as good as the discontinued ported 92... the solution seems pretty obvious." Right on again. Its like, if 90/92 was so good, discontinuing production would have been a poor marketing strategy! Fortunately, it was replaced with an improved product, that is made more stout and incorporated the fitment for C6 without the 90/92 homemade graft necessitate to fit!
Old Mar 3, 2012 | 02:04 PM
Dragracer_Art
I have an otherwise bone stock 27,000 mile 2005 LS2 with the A4 trans... which to my understanding is usually good for 330-340rwhp at best as it left the factory.
I added a brand new unported Fast102 and a set of Stainless Works 1-7/8" headers. I took it to Cartek, a local reputable tuner and had the car tuned and dynoed. The car made 381rwhp and 396rwtq.
That tells me the combination of intake and headers were good for a solid 40-50rwhp, maybe more... as I don't have a stock baseline to compare to. I've seen old articles showing factory stock dyno numbers in the 310-320 range also.
These were "easy" mods that anyone with common sense can install in their driveway on a Sunday afternoon. My car feels and drives MUCH better too. The Fast 102 and headers are money well spent... and should probably be some of the first mods done to an LS2 powered car.
Old Mar 3, 2012 | 07:02 PM
Gering's Avatar
Gering
Tolero Apto Victum
Old Mar 3, 2012 | 07:09 PM
  #33
Dragracer_Art
Originally Posted by Gering
And to add... the drivability of my car has not changed a bit. It has alot more power though and the shift points are much better also.
It was a fantastic upgrade all the way around. I feel the car now runs the way it should have when it left the assembly line.
Old Mar 11, 2012 | 05:31 PM
  #34
HC Mechanic's Avatar
HC Mechanic
On my LS2 the ported 102 did slightly better than the ported 92.
The 92 was done by Spin, and the 102 was done by Charlie at RPM.
Keep in mind the 102 doesn't need much work, and I believe Spin's 92's to be the best of what you can get...as he did a ton of work with the 92's. That's why I bought one from him, and was one of my first mods.
I believe the power difference between the 102/92 was in the single digits; but I would have to talk with Charlie to be sure. I was there when both of them were flowed on the bench with the same ported 243 head that ended up on my car.
I think the main difference came in when the 102mm TB was put on the 102 intake. That would make the most sense...as the new manifold is called a 102
Old Mar 11, 2012 | 08:49 PM
  #35
JUIC3D's Avatar
JUIC3D
St. Jude Donor '11-'12-'13-'14
Do you have your dyno graphs from all your mods?
Old Mar 12, 2012 | 02:32 PM
  #36
HC Mechanic
I have a few runs on paper at home, but Charlie has everything from start to finish. Most of them are in the head and small cam thread thread here:
http://forums.corvetteforum.com/c6-t...-the-tire.html
Old Mar 12, 2012 | 02:39 PM
  #37
JUIC3D's Avatar
JUIC3D
Ah, that's right. I remember reading that thread. 525/462whp with heads/cam/meth/vacuum pump, right?
To Ported FAST 102 or non ported?
Old Mar 12, 2012 | 03:18 PM
  #38
sallen619's Avatar
sallen619
Originally Posted by truckplay
Old Mar 12, 2012 | 07:30 PM
  #39
SUB VETTE's Avatar
SUB VETTE
SUBVETTE
The combination of ported 102 plus ARH headers netted me 53 rwhp on my 06 LS2. Great pair of mods to add.
Old Mar 14, 2012 | 12:48 PM
  #40
HC Mechanic
Yep...Charlie has it this week, and may post some updates.
