Harmonic balancer went out?
Old Mar 5, 2012 | 06:50 PM
roadtripwheels's Avatar
roadtripwheels
5th Gear
Default Harmonic balancer went out?
I've had a chirp for a while now, changed the accessory belt, compressor belt, tension pulley, alternator, finally took it to a dealership. Diagnosed as the harmonic balancer going out, 3 months after the power train warranty expired. Anyone else have this happen? Sounds more like a manufacturer defect. Those shouldn't go out at 58,000 miles.
Old Mar 5, 2012 | 07:34 PM
wysiwyg's Avatar
wysiwyg
The harmonic balancer wobble/failing appears to be a common issue.
Search for harmonic balancer on the forum and you'll find many posts discussing the issue.
There was a recent posting by a forum member who had success in having GM pay a portion of the bill for the HB replacement on his C6.
Edited to add: Found the link I mentioned above http://forums.corvetteforum.com/c6-c...eat-story.html
Good luck.
Old Mar 6, 2012 | 11:38 AM
stivette's Avatar
stivette
Common... mine started chirping at 9800 miles..
Old Mar 6, 2012 | 10:14 PM
Gering's Avatar
Gering
Tolero Apto Victum
OP: I had the wobbles with my stock balancer and replaced it with these two items. Now with many many miles down the road, I have never had a problem since.
http://store.katechengines.com/bille...sioner-p2.aspx
http://store.katechengines.com/ati-s...ts-v-p230.aspx
Good luck with your repairs.
Old Mar 6, 2012 | 11:24 PM
out4uv8's Avatar
out4uv8
Just paid to have mine replaced after having the chirp at 36k and just seeing the visual shake. If the engine looks like its going to twist out of the motor mounts and start doing 540* rotations down the road, then its definitely the balancer. Any seasoned GM mechanic has done the repair before and while its rated at 3.5hrs labor, it took them 5hrs on mine. Price ranges from $950 to $1050, but hopefully you can get out of some of that. Good Luck!
Old Mar 7, 2012 | 12:54 AM
paganharley's Avatar
paganharley
St. Jude Donor '11
Mine went out taking the timing chain cover and front oil seal. 1300 dollars. I replaced it with one from summit racing that was 25 per cent underdriven. Plus rated to 12000 rpms. No way was I going back with oem even if it did cost me more. I had 55k when it went.
Old Mar 7, 2012 | 08:09 AM
Gering's Avatar
Gering
Tolero Apto Victum
Old Mar 8, 2012 | 10:38 PM
mrbillbw1's Avatar
mrbillbw1
Buy an aftermarket pulley and do your homework to find someone in your area that is familiar with this procedure on a C-6. If they have done it before they will be able to do it way cheaper than any dealer. It can be done in 3.5 to 4.5 hours if they know what their doing. My local blower shop did one for me at 4.5 hrs. Put car up on hoist, remove front suspension cradle, disconnect steering rack (leave hoses connected) and push to one side, then access harmonic damper. Its not that bad of a job for a well qualified mechanic that has done a few. If its their first then it will be a PITA!
To Harmonic balancer went out?
