Harmonic Balancer
Old Mar 13, 2012 | 10:55 AM
Redrocket1045's Avatar
Redrocket1045
Default Harmonic Balancer
I am thinking of replacing the stock GM damper with something more reliable (while installing a new cam). I have heard ATI Superdamper makes an excellent damper but there are those that say it's overkill. What about Powerbonds' damper? Any issues? Thanks.
Old Mar 13, 2012 | 11:49 AM
Bad News's Avatar
Bad News
Do you have excessive wobble or something from your factory balancer? If you were going to change it I would swap it out for a under drive balancer. The two most common brands you will hear about here on the forum are ATI and Innovators West.
Old Mar 13, 2012 | 12:38 PM
wysiwyg's Avatar
wysiwyg
I recently had my harmonic balancer replaced under warranty due to excessive wobble; however, if I had not been able to replace it under warranty, I planned on going with the Powerbond. In my research, people seemed very pleased with them, and they are reasonably priced.
You should be able to get the stock size at a local parts house. I think O'Reilly may stock them or be able to get it fairly quickly.
Powerbond also makes under drive balancers.
Powerbond part numbers:
PB-1117-N OEM replacement for LS2
PBU-1117-SS10 - 10% under drive for LS2
PBU-1117-SS25 - 25% under drive for LS2
If you have questions, give them a call (number is listed on their site). http://powerbondparts.com
Old Mar 13, 2012 | 12:56 PM
Redrocket1045
No..... no wobble. It's ok for the moment. But since I plan a cam install, I thought of upgrading the factory damper to something better and more reliable.
Old Mar 13, 2012 | 01:40 PM
Bad News's Avatar
Bad News
Well if you are that far into the motor anyway with the cam install and you have the extra $$$ I don't see why not to upgrade. Definitely won't hurt anything. Only thing you have to decide from there is if you want an under drive damper or factory size one. I personally can't comment on an under drive as I am supercharged and actually have an over drive damper however I know a lot of head & cam guys who switched to an under drive damper and love it.
Old Mar 13, 2012 | 06:33 PM
glenB's Avatar
glenB
St. Jude Donor '08-'09 & '12, '14
Do a search on threads with timing chain failures and see what pulley they were using, then get an ATI
Old Mar 13, 2012 | 06:41 PM
CGZO6's Avatar
CGZO6
This is good advice.
Old Mar 13, 2012 | 07:26 PM
1fastbob's Avatar
1fastbob
Yup, spend the extra bucks and get an ATI.
Old Mar 13, 2012 | 08:53 PM
DSOMC6's Avatar
DSOMC6
That's a wise choice to swap it since you have it apart.
I like the ATI, it's rebuildable but is definately pricey.
I installed the PB and have to say it spins about as true as any pulley I've seen. I'm pretty impressed for the $$.
As far as timing chain failure with a UD; there was a thread or two in the past trying to relate the two...not sure what if anything was concluded. I replaced my timing chain with the Katech C5R last year when I R&R'd the heads/cam and have had no troubles.
Old Mar 13, 2012 | 10:44 PM
Redrocket1045
And that exactly what I was thinking - to use a Katech C5R chain with an upgraded damper.
I know ATI is known as an excellent damper and like I said - there are those out there that say it's overkill.
Has anyone has any issues using a C5R chain and a Powerbond damper?
Old Mar 14, 2012 | 06:23 AM
glenB's Avatar
glenB
The pulley isn't just about 'spinning true', it's about cancelling crank vibrations and not transfering them throughtout the valvetrain.
Look up Taken19, he just had a timing chin failure using an underdrive pulley AND he was using a C5R chain.
If it was left stock you'd probably be ok, but modded, I wouldn't do it.
I'd also look into the Cloyes TC set
ATI makes an UD pulley, if that small extra power at the top is important.
Old Mar 14, 2012 | 10:08 PM
Redrocket1045
I think you're right. ATI it is.
Old Mar 14, 2012 | 10:26 PM
DSOMC6's Avatar
DSOMC6
I commented on how "true" PB pulleys run simply to state the quality of the machining (compared to oem or other UD's I've seen) not to explain what HB or dampner is desinged to do.
Taken19 was on a roadrace course when his chain broke where the engine spends the majority of the time in the 4-6k RPM range.
There is no factual information to base the UD/timing chain failure theory. Far too many people run this set-up without failure to show any real correlation.
Old Mar 14, 2012 | 10:37 PM
gotjuice?'s Avatar
gotjuice?
St. Jude Donor '13
I installed this one under warranty and have another one to to tomorrow evening out of warranty. Both of them wobbling. On both of these I am using factor parts. I have installed a couple of the Powerbonds with no issues. After reading about the failures on race tracks, I am not sure I would install any more of them. At least not on Vettes that really drive there car hard. I would look at the ATI unit or the IW.
Old Mar 15, 2012 | 07:54 AM
1fastbob's Avatar
1fastbob
http://forums.corvetteforum.com/auto...-for-cure.html
At the above link a pretty good discussion on timing chain failure and damper issues.
Old Mar 15, 2012 | 09:25 AM
wysiwyg's Avatar
wysiwyg
Hmmm...were the Powerbond's OEM sized or UD? The OEM sized Powerbond had the dampening rubber material like the OEM. The pics of the Powerbond UDs I saw did not appear to have the rubber material.
I'm not sure how much of an impact it makes on the performance of the balancer.
Thanks for the excellent work you did on the replacement!
Old Mar 15, 2012 | 10:06 AM
ramairroughneck's Avatar
ramairroughneck
Taken had an Asp balancer during his timing chain failure. Why are you guys second guessing the Powerbonds? It seems like there are more PB's on c6's than any other balancer. Have there been many failures with powerbond balancers?
To Harmonic Balancer
Old Mar 15, 2012 | 10:37 AM
JUIC3D's Avatar
JUIC3D
St. Jude Donor '11-'12-'13-'14
I have a powerbond UDP on my car and have not had any issues. With that said, after reading of my buddy's(taken19) timing chain failure, I would not hesitate to buy an ATI dampener in the future.
The powerbond unit is just a pulley, it doesn't do anything to reduce engine harmonics--the ATI does.
That alone is worth peace of mind to me, even if it is overkill.
Old Mar 15, 2012 | 11:30 AM
5 Liter Eater's Avatar
5 Liter Eater
St. Jude Donor '11
I got this one but have yet to run it yet. Anything is better than stock.
http://www.summitracing.com/parts/PFS-80033/
Old Mar 15, 2012 | 12:13 PM
ramairroughneck
I don't much about them but I think it is a harmonic balancer. I took this directly from Scoggin's websight.
POWERBOND balancers eliminate common failures in standard and performance balancers by positively bonding the dampening rubber to the metal components under extreme heat and pressure. The state of the art bonding process used on all POWERBOND models eliminates spinning of the inertia ring and separation of the dampening material in even the most highly stressed applications. Offered in standard diameter, 10% underdrive, 25% underdrive.
