Old Feb 20, 2015, 06:54 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine and Powertrain
Print Wikipost
2011 C6 A6 Transmission shift problem
Old Mar 17, 2012 | 12:37 AM
ntelligent's Avatar
ntelligent
Default 2011 C6 A6 Transmission shift problem
Hello Everyone!
I have a strange problem with my C6 A6 transmission shifter/tranny? It seems as if sometimes when have driven for a while in S or D mode if I stop and shift toward park gears will seem to be in strange places. Like, Neutral will be in between gears, park may be reverse, looks like I have an extra gear S, D, gear?, N (in the black area), P????
However, here is the interesting part. Put the car in park. Go backwards through the gears and everything lines up. Go figure. Also, it seems as if the gear will move from S to D by barely tapping. So I dont know whats loose or broke. Please help!
Old Mar 17, 2012 | 01:05 AM
HOXXOH's Avatar
HOXXOH
Originally Posted by ntelligent
Hello Everyone!
It's either the cable slipping or the nut holding the arm on the transmission has come loose.
It's under warranty, so get to your dealer soon before it gets worse and won't shift at all.
Old Mar 21, 2012 | 10:28 PM
ntelligent's Avatar
ntelligent
Problem solved! When the dealer installed the borla atak they knocked a cable loose on the transmission. They had it fixed as soon as it was on the rack. Apparently this is a relatively common occurrence when installing a new axle back exhaust system. At least at my dealership
To 2011 C6 A6 Transmission shift problem
