low range fuel on dic
Old Mar 21, 2012 | 06:54 AM
xgto's Avatar
xgto
Default low range fuel on dic
2005 C6 MN6 - My fuel gauge works perfectly, but since the last 2 fill-ups my low fuel message no longer alerts me. The gauge is working correctly because both time I filled 14 to 15 gallons. Is this some kind of sensor problem ?
Old Mar 21, 2012 | 01:17 PM
FNBADAZ06's Avatar
FNBADAZ06
My Low Fuel indicator usually comes on when I have roughly 40 miles of range left, and I'm averaging 20+ MPG on the DIC. For my car, this is at the last line on the fuel guage.
The C6 has 18 gallon capacity between the two saddle tanks, so if you are filling up with 15 gallons to full fuel, you haven't reached the "reserve fuel" level (roughly two gallons).
IMHO
Old Mar 21, 2012 | 01:27 PM
RicK T's Avatar
RicK T
Might be worth buying a couple bottles of Techron additive and run a couple tanks of gas with the additive through the car. Could just be some deposits causing a problem.
Old Mar 21, 2012 | 01:35 PM
FloydSummerOf68's Avatar
FloydSummerOf68
IMHO
14-15 gallons won't be enough to set the light off.
I'm usually putting in around 16.5
Old Mar 21, 2012 | 01:51 PM
BEZ06's Avatar
BEZ06
Mine came on yesterday.
I drove about 6 or 7 miles before stopping to put in gas.
It took 17 gallons ($70!!!!)
So....it probably came on with about 16.5 gals remaining.
Bob
Old Mar 21, 2012 | 09:10 PM
xgto's Avatar
xgto
The low fuel indicator would come on right at the 40 miles to go on the dic, now I have to manually page through to see low range note.
To low range fuel on dic
