Compression test results, normal numbers?
Old Mar 24, 2012 | 08:46 PM
PRAY's Avatar
PRAY
Originally Posted by ashanson
You are correct, I shouldn't have used the term overlap, I should have specified long intake valve opening after BDC. I was just thinking a large overlap cam has a longer durations overall.
For break-in, I was referring to my aftermarket build, I believe it takes more than a couple miles to get full compression, no?
My 416 was 190-195psi when checked at 122* at 860 miles, and 210-215pai when checked at 154* at 1,800 miles. It also went from 555/509rw to 573/530rw but that could have been from a lot of stuff.
Old Mar 25, 2012 | 03:57 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Originally Posted by PRAY
But oil pressure of 25psi at idle is a little concerning.
With oil temp at 180'F (not fully warmed up), our idle oil pressure showed:
28 psi on 2006 LS2
27 psi on 2009 LS3
Old Mar 25, 2012 | 08:18 PM
PRAY's Avatar
PRAY
28 psi on 2006 LS2
27 psi on 2009 LS3
Hmm. Haven't had a stock LS2 or 3 but my LS3 416 and all my other LS motors have idled around 40psi.
Old Dec 14, 2025 | 08:27 PM
dfierro's Avatar
dfierro
2nd Gear
Adding to an old thread- this is one of the few places a Google search result shows when trying to find out an acceptable engine cylinder compress range for a C6 corvette engine.
I recently purchased a used 2011 Corvette C6 M6 GS, completely stock, 49K miles that has the LS3 engine with the dry sump oil system. I did not have any maintenance history on the car as it was purchased from a dealership with no prior paperwork ( I would have preferred to buy my C6 directly from a previous owner, but that is another story).
I took it to the local Chevy dealership for a compression test , here were the results. I hope they are useful to someone. I know about the 10% max variance desired between the cylinder that has the max compression and min compression numbers. My variance in the cylinder compression numbers is under 5% so that's good. I still have not been able to easily find what are the factory stock cylinder compression numbers for a C6 LS3 engine, so if anyone has a link or knows that info feel free to reply. Thanks.
One observation I see- it appears the compression drops off from the front of the engine to the rear (towards the windshield) on both sides of the engine (driver side front to back: 1,3,5,7; passenger side front to back: 2,4,6.8). I am going to take a guess, this could indicate a problem with the head , such as a gasket leak towards the rear , on both sides? Or maybe the LS3 engine has known heat or wear characteristics that could explain this. I am new to C6s.
Cylinder number PSI
1 192
2 191
3 190
4 188
5 185
6 186
7 185
8 183
Old Dec 14, 2025 | 09:01 PM
NORTY's Avatar
NORTY
Originally Posted by Thomasmoto
Yeah 160 is pretty much normal. Most techs won't get too worried til you get over/under 15 percent deviation.
LOL, yeah, for a 1982 350 with 8.5:1 compression.
LS2 should be around 190ish (dry.) And 220ish (wet.)
LS3 a little higher
LS7 even higher yet.
Most important is that all the cylinders are relatively equal. No single cylinder being "lazy."
