Vette failed emissions
Old Mar 24, 2012 | 01:18 PM
marz's Avatar
marz
Default Vette failed emissions
I am posting a pic of the emissions fail to see if anyone can interpret this. I have replaced the MAF sensor and both pre-cat O2 sensors. Reset and the check engine light went off. Took in for inspection and failed and then the light came back on as I left.
Hope you can help.
Thanks.
Old Mar 24, 2012 | 01:19 PM
duramaxsky's Avatar
duramaxsky
Give it to me. We don't have testing where I live so I will be able to use it. PM me for an address to sent it and the pink slip.
Old Mar 24, 2012 | 01:31 PM
marz's Avatar
marz
Ha! They used to not have testing here in Texas either, but it's here. Maybe blow the thing up. lol
Old Mar 24, 2012 | 02:57 PM
magls2's Avatar
magls2
Any error codes in your computer will cause your car to automatically fail in California independent of what the code is
Old Mar 24, 2012 | 03:04 PM
filmjay's Avatar
filmjay
St. Jude Donor '10
Looks like the Evap Purge and o2's are disabled. It's likely your car is, or has been, tuned and those sensors are tuned out.
Old Mar 24, 2012 | 04:35 PM
Bill Dearborn's Avatar
Bill Dearborn
What made you decide to replace the MAF and the O2 sensors? So what codes are present on the car now? You have to know what the codes are if you hope to do any diagnosis. That sheet of paper is worthless from a diagnostic standpoint other than telling you a couple of systems weren't ready when the test was run.
Bill
Old Mar 24, 2012 | 07:33 PM
marz's Avatar
marz
Bill
It had a P-158 and 160 co showing. Looking at all the stuff all over the internet most stated it was usually the pre-cat O2 sensor out. I had it scanned and it showed could be MAF or O2 sensor. So...now I am back to the drawing board. I have been reluctant to take it back to the dealership because they will charge me an arm and a leg and was hoping to do it myself.
Thanks.
Old Mar 24, 2012 | 08:24 PM
marz's Avatar
marz
Bill
Thanks.
Old Mar 24, 2012 | 09:05 PM
Bill Dearborn
Thanks.
Both of those codes are for Bank 2 Sensor 2. That means they point to the post cat sensor on the passenger side. In the first diagnostic one of the things that can cause the code is a high voltage reading from the front O2 sensor with a low reading from the rear O2 sensor. The second code indicates the front sensor is reading a middle level voltage but the rear sensor isn't reading a corresponding level.
Take one of the two sensors you removed and use it to replace the passenger side post cat sensor and see what happens. While doing that check the wiring to the rear sensor and see if it is shorted to the exhaust or frame.
See Attached Diagnostic Procedures
Bill
File Type: doc
Old Mar 24, 2012 | 11:08 PM
ChevyDave's Avatar
ChevyDave
post-cat... i thought you got that fixed... you did pre-cats??
http://forums.corvetteforum.com/c6-t...post1580331542
Old Mar 25, 2012 | 09:58 AM
haljensen's Avatar
haljensen
Passing requires a certain number of "drive cycles" between any changes to the computer. If you re-set any codes you have to cycle the computer xx times to get a new base reading.
2008? Why does the test show a 6.0 L engine? Wrong inputs could cause bad readings.
Old Mar 25, 2012 | 10:14 AM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
you have private corvette shops in the area, why not use them vs. a dealer?
Old Mar 25, 2012 | 06:35 PM
TxPres's Avatar
TxPres
Your sheet shows the Catalyst, Evap, and O2 NOT READY!
As stated above, this means that you have not driven it enough cycles/miles. Even if you unhook the battery, it will take several cycles and a few miles before it will pass.
I had this problem on my LX470. Disconnected the battery to replace the drivers side headlight and only used it to go to the store. Then the next day drove it to inspection station. Did not pass. (Just like yours, my Catalyst, etc was NOT READY).
They asked me if I had disconnected the battery recently and I said yes.They then told me to drive it about 50 mi and several off/on and bring it back. It passed then.
Good Luck!
Old Mar 25, 2012 | 11:32 PM
marz's Avatar
marz
Good Luck!
That's what the guy at the inspection shop told me too. I have driven it about 80-90 miles since then. Going to take it back next week. There are only a couple of Vette shops here in town that know what they are doing and keep your car two weeks. Can't do that. Will check the post cat O2 sensors too.
Thanks everyone.
Old Mar 26, 2012 | 10:49 PM
cam75w/ls1's Avatar
cam75w/ls1
You are in mine and Brian's area. Brian w/ Reckart Performance is a sponsor on here. You should call him and see what he can do for you. I'm in Leander and he's in Cedar Park. We both are Corvette shops.
Old Mar 27, 2012 | 03:41 PM
ChevyDave's Avatar
ChevyDave
Marz... you get a good inspection yet?
someone asked almost your identical question about 'not ready'.
see link, see post #6 , might be helpful
http://forums.corvetteforum.com/c6-t...ive-cycle.html
To Vette failed emissions
